Originally Posted by Wannabe Actuary
certain batches of the harmony ones had problems learning in general. you shouldn't have to learn any commands though, as the profiles should be fixed at this point. if not, go ahead and add the DMP-BD30 (no K at the end) and you should get the best of the profiles from the 30/50/35/55...all their remote codes are the same.
despite owning the 55, I'm using the profile for the 30 and it's working very well
Thanks - reprogrammed using the 30, and its much better.
Appreciate the help!
![Stargate (15th Anniversary Edition) [Blu-ray]](http://cdn.avsforum.com/e/ef/50x50px-ZC-efe07684_B002KPINY8-611I5Fw82zL.jpeg)
