Originally Posted by topshag01
what I'll be missing by hooking up the 7.1 analogs to the Panasonic is the inability to use them for the Elite's SACD and DVD-Audio since there's only one set of analog inputs to the 3805. I didn't have too many multichannel formatted CD's, but the ones that I have weren't cheap, and I particularly liked listening to the Eagles Hotel California. I was always amused at the massive quantity of inputs and outputs on the 3805.....just now to find that I'm a set short of my needs.....arghhhh.
Get a Philips switch (PH-61148). $25 online. It's a manual switch - real low-tech - and works like a charm. It only has six channels, though. But, since there are no 7.1 SACD or DVD-Audio discs, you can probably run 5.1 through the switch and run the rear speakers from the BD55 direct to your receiver. At any rate, I am using this switch and am happy with how it works. You need to get up to insert a disc anyway, so the lack of remote control is no big deal.
Zektor has pricier switches, in the $250 range.
![Stargate (15th Anniversary Edition) [Blu-ray]](http://cdn.avsforum.com/e/ef/50x50px-ZC-efe07684_B002KPINY8-611I5Fw82zL.jpeg)
If it doesn't, there's a problem at the source device. The Denon merely takes whatever analog audio is fed to the external inputs, amplifies it, and sends it along to the speakers.
