Originally Posted by
Longballsd
Your receiver has audio inputs so if you buy the BD55 you can hook it via these inputs and receive the lossless codecs.
The BD35 does not have the audio outputs so you'd have to hook it up via optical or coax in which case you'd receive the lossy DTS and DD and not lossless.
Can you tell the difference in sound? Some say they can and some say they can't. I haven't had mine long enough to tell yet. I have an even older Yamaha RX-V995 hooked up to my BD55 via the 5.1 channel inputs and for me I just wanted it because if I went for blu ray then I wanted the best sound. That being said, at this point I'm not sure I can tell the difference.
The BD55 is $100 more than the BD 35. Is that a lot of money? To me it wasn't. The analog setup in these older receivers isn't a piece of cake because you'll need to boost the sub output.
Hey Long,
Yea, I had a hard time trying to decide between the BD35 & BD55, and ended up with the BD35, yea I know it was only 100 bucks for the 55, but, for me, this is ok for now, I'm in the middle of finishing my theater in my basement, ran all new wires, etc, but I'm playing the waiting game for now, after 6months, maybe a year, then getting a RX-V-3900 or the new Z11, and some other up'grades....
I just ordered my BD35 yesturday !!!, and got a great deal...
I will let you know, hopefully Friday after work & see how it works, and it will be nice to hooking it up to my Samsung LN-T4669F..... What's the best break-in Blue ray, for 1st time playing???
This may sound funny, but I enjoy DD & DTS just fine, I have not spent any time with the newer audio formats, so this is new territory to me.... I'm ready for something new....
My 2095 has dual adjustments in the on screen menu, where I can control the bass factor, both in DD and DTS, I have my DTS in 5 out of 10, and it's way louder than regular level at zero....
My Sub output will be fine, I have eight 10"subs and a RSW-12 running at once....
I'm praying for a friday delivery!!!
Thanks...
