Originally Posted by boylan13
I've noticed the same behavior with DVDs on the BD55 - reverting back to 60p output even though 24p is selected in the set-up menu. I've found that I can "force" it back to 24p during DVD playback in the "Display" menu on the BD55, but I'm not sure why this is necessary.
It's been suggested that possibly it's the fault of the Onkyo receiver in the chain preventing the 24FPS output when its on-screen menu is enabled but I have not verified this or tested with a direct connection to the display to see if it still occurs. Plus it doesn't happen on BD so that's why I don't suspect the receiver. Since I can force it to 24p in the Display menu, I'm not too worried about it.
I don't think its your receiver. I'm connected directly to the TV via HDMI, with 24P enabled in the HDMI setup menu.
Every time I insert a DVD, I have to go to the Display menu and activate 24P (When 24p is not enabled in the Setup menu, this option is not present.) Blu-rays switch to 24P automatically.
I am glad someone decided to call this a "bug." I was thinking of it as an "annoying default."
![Stargate (15th Anniversary Edition) [Blu-ray]](http://cdn.avsforum.com/e/ef/50x50px-ZC-efe07684_B002KPINY8-611I5Fw82zL.jpeg)
