AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Panasonic DMP-BD35/55 Owners Thread
Official Panasonic DMP-BD35/55 Owners Thread - Page 302
post #9031 of 14893
Originally Posted by Randyja View Post
I just called my local store inquiring if they had the Panny BD-35 in and I was told the Panasonic rep had just left the store and that the BD-35 was discontinued. Is this true or should I shop elsewhere?
True. Previous posters say they are still available at some Costco stores.
post #9032 of 14893
Originally Posted by tonngo0 View Post
check here
http://panasonic.jp/support/global/c...5/bd35_na.html
Thanks for the link. Seems a bit obtuse. Any reason to be wary of agreeing to the license under the laws of Japan?
Anyway, it IS curious that Panasonic USA web site only has 1.5 to download. And download to CD is my best option as my BD35 is not in a position to be connected to the internet
post #9033 of 14893
Originally Posted by jbrim View Post
First, if there is a better area to post this let me know and I will gladly ask this question there.
I have the BD-35 along with and Onkyo 805 as my receiver. I have been fairly happy with the BD-35 but wanted to find out from the members here that have both (or those with a good perspective) to chime in on how these two units compare.
My understanding (and I am a novice in this area) is the PS3 will not be able to pass the HD audio to my Onkyo, instead will decode it and send it as LPCM. From what I have read this will not sound nearly as good as my BD-35 because it will send the audio in Bitstream which allows the Onkyo to decode.
My in this comes from the fact that I have an option to obtain a new PS3 for $300 so I am trying to decide if this makes any sense. It is really difficult to Google this and get a reasonable answer; most sites state the PS3 is the best thing on the planet because it boots up quicker (means little to me) and is a great multimedia unit with its gaming option.
The audio does mean a lot to me as well as the ability to upconvert DVD's; can some of the folks here that are more technical chime in if the PS3 would do nearly as good of a job as my DVD/BD player as the PS3 when both audio and video are compared. Again, if there is a decent thread on this and you do not want this post to head into that please provide the link and I will head there.
Joe
I have the Onkyo 805, PS3 and BD35. Before getting the BD35 I always thought that TrueHD wasn't as good as PCM and DTS-MA. However after getting the BD35 and having it bitstream to let the 805 decode I feel that their is no difference between the codecs, all are phenomenal and it's all mix dependent. Basically I find no difference on PCM and DTS-MA tracks but with TrueHD tracks the BD35 bitstreaming to the 805 sounds better. I'm thinking that the PS3 doesn't take into account dialnorm metadata and since it outputs it as PCM the 805 doesn't any dialnorm adjustments. But with the BD35 bitstreaming and letting the 805 decode it knows the dialnorm metadata to apply. Also since the 805 is a THX certified receiver Dolby sources get bumped up +4db in comparision to DTS material.
post #9034 of 14893
Originally Posted by jayfore View Post
Do you know of a post where I can see more information about this? I'm not really sure I follow what you're doing with the player and wireless, so it has piqued my interest.
Ok, Here is the deal. I do not have the network connection where my BD35 is. So to connect BD35 to internet I had following options.
1. Pull a cable from my router to BD35. (This was out of question)
2. Use a Powerline ethernet adapter pair and extend it (This cost was about $100)
3. Use a dedicated Wireless extender (Costs $$$)
4. Use a capable router that can be flashed with DD-WRT that will make it extend my network wirelessly.
I picked option 4 as I found WRT54G-TM at my local T-Mobile store for $20. I found the procedure to flash DD-WRT on it from dd-wrt forum. And presto, I now have wireless extension of my home network. The router is sitting near BD35, one of it's Lan port is connected using lan cable to BD35.
post #9035 of 14893
I have a DB 55 and I use component video cables. I read in Home Theater that bluray disc copy protection prevents 1080i via component cables. Is this true? How do I know that my DB55 is providing 1080i to my projector? I have both the projector and the DB55 set to 1080i.
post #9036 of 14893
You can get Blu-ray play at 1080i but no for DVD.
post #9037 of 14893
Originally Posted by boylan13 View Post
I've been looking for a subtitle button on that remote since September 30th. Still haven't found one. And if you've tried grabbing one from another Panasonic DVD player remote that has a subtitle button, and that code does not work on the BD35 then I'm afraid you're have to painfully enter the menus each time you wish to enable or disable the subtitles.
I have a Harmony remote also, and the Subtitle button shows up but does nothing (as someone else has mentioned in this thread). I saw the post that says to go into the setup and set the subtitle language to "0000" but what's the deal? Is there truly no other way to easily toggle the subtitles on/off? Crazy!
post #9038 of 14893
I don't know if this is the problem, but I rented How the West was Won and the pixelized squares started forming and video messing up like crazy. I then found that the disc I rented had one big fingerprint on it. Cleaned it with my shirt(it's bluray) and walaaa, the movie played flawlessly then.
post #9039 of 14893
Originally Posted by Makaveli6103 View Post
I have band of Brothers of Blu Ray and never had this problem. Maybe your disc is scratched or somethiing
I was replying to this thread above by the way.
post #9040 of 14893
I did the same, as I had the linksys as a spare after A FIOS install.
post #9041 of 14893
Originally Posted by stash64 View Post
I wish I could give you some hard feedback on our BD35/55's. I've been calbrating my equipment for more than a year now using an Eye-One meter and with very good results, but something went buggy recently in the meter or the software I was using. I wanted to check my BD35 and see how close it was to my Toshiba HD-XA2 but won't be able to do so until I figure out this problem. Right now, I am using the same TV settings I used with a Samsung BD-P1400 and I always set up my players so that there is no video manipulation on the player end (as best I can determine). All video adjustments are made through the TV. My BD-35 looks very good with the BD-P1400 settings, so I would expect any tweaks will be minor when I do get my calibration equipment working properly again.
Would you mind giving a brief outline how to do a calibration with the Eye-One?
post #9042 of 14893
I owned a BD30 for nearly a year and really loved it. Unlike my A35 which constantly had problem reading discs, out of 200 BD rentals my BD30 maybe hiccuped five times.
I've had the BD35 for about six weeks, and I swear, about 25% of movies seem to have problems. Namely I get picture and audio breakup, often for several minutes. While watching Dr. No last night I missed about five minutes of the movie because of read problems.
These are BB rentals, but like I said, with the BD30 VERY RARELY had issues. Has anyone noticed the BD35 seems to be much more picky about reading discs? Do I have a bad unit?
One reason I really liked my BD30 so much was that it was rock solid, and I'm quite disappointed the BD35 is acting more like my A35.
post #9043 of 14893
I have a BD35 and A35 and haven't had a problem reading disc on either. Maybe I don't rent enough movies?
post #9044 of 14893
I'm not sure why you guys are flashing it etc - i have the Linksys ethernet bridge i had been using on a computer (configed it to my network using the disc etc a few years ago). Plugged it into the BD35 and it worked. Didn't need to flash or do anything like that.
post #9045 of 14893
You can program in a sequence for subtitles on the Harmony. See this post:
http://www.avsforum.com/avs-vb/showt...8#post15241368
post #9046 of 14893
I have a problem with my BD-55 with "The Mummy: The Dragon Emperor" the error message was the "Network Connection Failed" even though I've never had any connection problems with my player. To stop the message from popping up every few minutes, I had to restart the movie with my Ethernet cable disconnected.
Other movies work correctly with using BD live. I am thinking the problem is with the connection that the Mummy movie is attempting to connect too.
I must say that the BD-55 is very slow in starting any Blu-ray movie and reading the disk when the disk is Blu-ray. Regular DVD load fast and operate just like my regular OPPO 971 and regular Panasonic DVD player. I am very disappointed and talking with people that have other brands they state that this is a common problem with other brands. Is Blu-ray players ready for prime time?
Mike
post #9047 of 14893
Thank you! I will give that a try. For some reason, this post did not come up in my search.
post #9048 of 14893
I just recently replaced my 10 year old big screen and Sony DVD player with a Toshiba 54'' HD TV and a Panasonic BD35 Blu-Ray player. While I'm thrilled with the video, I now see that my audio suffers. I'm using an old Kenwood receiver that only has Dolby Digital (no DTS). A few Blu-Ray movies I have bought, such as Wall-E, only send out a DTS signal - so I can't use my receiver. I guess it is time to look at a new receiver.
I would like to get your suggestions. I've been reading about the Onkyo 606, bit I have a few doubts about the receiver - for example, I heard it does a bad job upscaling DVD video - is there a way I can just let the Panasonic take care of it?
In my set-up I would probably hook up my Time-Warner HD DVR to the receiver as well as the BD35 by HDMI and then run it to the TV.
Thanks for your help! ~Russell
post #9049 of 14893
Mike
I couldnt get Kung Fu Panda to go to BDLive w/my BD35. I think it may be due to the fact i don't have an SD card in the player?
post #9050 of 14893
I don't own any blu rays. I've watched about 12-15 blu rays and another 5-6 dvds from Netflix (as well as about 10 dvds I own) all of which have played flawlessy on my bd55. Regardless of how the disc looks, I clean every one thoroughly with Mobile Fidelity's Shine-Ola and demagnetize with a cheap Radio Shack high power audio/video tape eraser before playing them.
I also use a Marigo dvd mat on top of disks.
post #9051 of 14893
Yep you need at least a 1GB card,make sure you format the card.
post #9052 of 14893
Joe
Joe,
Great questions. I had used a PS3 exclusively for BD playback for nearly 1.5 years up until it died less than a month ago (I also own a Samsung 1500 that I picked up before the PS3 died to use as a secondary player for the kids upstairs). I purchased the PS3 almost exclusively to play BD movies on and have watched (roughly) 250 BD and DVD's on the PS3 since purchasing it.
As for the audio, I did a side-by-side test using my PS3 and Samsung 1500 (Samsung bitstreams the lossless codecs just as the BD35 does) and for most titles I simply could not tell a difference (I also have an Onkyo receiver). In some cases the audio was slightly louder via bitstreaming, but the PS3 sounded just as good once you level matched the audio. I still do not see bitstreaming as being a negative for the PS3 or a positive for bitstreaming players. Perhaps on extremely high end gear you may hear more of a difference, but at the end of the day lossless is lossless.
As for DVD upscaling I would give the BD35 the nod. It is not a night and day difference with regards to upscaling, but the BD35 performs slightly better based off my my experience. The BD35 also has the ability to upconvert at 24fps. I don't believe either my PS3 or my Samsung 1500 can do that. I also feel that the PQ for Blu-Ray on the BD35 is slightly better than the PS3 and Samsung 1500. I calibrated all three players using the Blu-Ray DVE disc along with a calibration disc found here at AVS in the display calibration section. It could be placebo but the BD35 seems to have a little more depth to the picture and blacks are a little more accurate for me. It is very close, but I would have to give the nod to the BD35 (note I am watching this on a 1080p projector on a 100" screen from 11ft away. On a smaller screen/further distance, the differences may not be as noticeable for both DVD upscaling or BD playback).
The PS3 is definitely faster at loading and playing discs. Sometimes noticeably faster (Lost Season 3 comes to mind). But I don't see this as a deal breaker for most people as the BD35 is still fairly quick with regards to most movies.
I also really prefer the PS3 XMB menu to the Panasonic menus. Again, not a huge deal, but still something to consider.
The other thing about the PS3 is that some people complain about the noise and its non-traditional shape (cannot stack anything on it). I kept mine in a very well ventilated cabinet in a cold room. I never really noticed the noise at all during BD playback, but the BD35 is silent and draws less heat. Not sure if this is an issue for you or not. The PS3 also does not support IR out of the box if you use a universal remote (although there are several workarounds).
In short, unless you are a gamer, I am not sure what the PS3 can really offer you that the BD35 does not already offer you. I would be inclined to save the $300 unless you really like to game and want to have a second BD player.
post #9053 of 14893
Mike
Depends on the BD movie (BD-J definitely plays a role). My BD35 is almost as fast as my PS3 for some titles and is much slower for others. My BD35 and Samsung 1500 are very close in loading times (the 1500 may be just a tad faster). I don't find the loading times to be a dealbreaker for me, but I have a feeling that you will find similar loading times for most stand alone players right now. I suspect this will improve in the future, but you may want to try out a PS3.
post #9054 of 14893
Me too, no problems and I get at least two rentals a week... I always clean the disks before I watch them also.
post #9055 of 14893
Yes. You need an SD card to utilize BD Live.
post #9056 of 14893
Welcome to hidef The Onkyo 606 is a very solid receiver for the money IMHO. As for upscaling, the 606 can upscale material to 1080i, but in your case you would just would just be using the 606 HDMI as a passthrough for video to your HDTV. It should not apply any upscaling. And yes, you would most likely want to hookup everything via HDMI into the receiver and then out to your HDTV over HDMI.
post #9057 of 14893
If you are using a HDMI in and out no up scaling takes place it is a pass through, The TV will take care of it.
post #9058 of 14893
It could be a bad unit. I've rented a number of BD titles and have had no issues with my BD35. I too used to have the BD30. If anything, my BD35 is more reliable...though I rarely had an issue on the BD30.
post #9059 of 14893
The Aiptek GO-HD is supposed to use the H.264 codec and generates .mov videos on an SD card, easily playable on my computer. However, the cards show no files when I attempt to play them on my BD-35, which is supposed to read AVCHD. I suppose I didn't research things carefully enough (again.)
Can anyone tell me what is wrong? Is there a solution?
Thank you.
Frank
post #9060 of 14893
I am user of the BD 35 and am very happy with it so far. Excellent video and audio quality
