AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › "YOUR" subwoofer picture thread
"YOUR" subwoofer picture thread - Page 58
post #1711 of 2536
x-post from the JTR thread....CAP!
post #1712 of 2536
post #1713 of 2536
This thread should be a "sticky". Moderators?!?
post #1714 of 2536
just finished building these F-20s yesterday. Still need to veneer them
post #1715 of 2536
Sub for HT Purpose
post #1716 of 2536
Have posted these before, but what the heck ....
post #1717 of 2536
I think you need bigger mains now.
post #1718 of 2536
Wow those are large and in charge! I think you should check the carpet below the left main, I believe it wet itself!
post #1719 of 2536
Mains are up next. I'm going to build some Econowave SR Compacts I think. Room setup is temporary as I plan to convert a pretty good size storage room into a dedicated ht room after my other projects are finished
post #1720 of 2536
Since I always enjoy seeing other people's setups, here's mine:
For the record, that's a 58" plasma on the wall. Everything else is so big, it looks like a 32".
The subs are a pair of DIY 18" TC Sounds LMS Ultras in 24" cubes powered by a pair of Behringer EP4000 amps.
I have the amps up in the floor joists just below my listening room. I didn't have room for the amps and with the cooling fans so loud, it's better that they are down in the basement.
My subwoofer progression has been a SVS 20-39PC+ from when they first came out. Then a SVS PB13-Ultra, a Submersive HP, and I even tested dual Submersive HP's. The dual LMS Ultras are by far the best subs I've ever heard. They work perfectly with my room.
My setup is primarily a 2-channel audio setup that is home theater capable.
post #1721 of 2536
Very nice, TJHUB. I like the acoustic panel arrangement as well.
post #1722 of 2536
Thanks. Most people don't seem to like the acoustic panels.
I have a similar arrangement on the rear wall.
post #1723 of 2536
Nice job TJ. Those subs definitely make the TV look small.
I like what you did with the amps. That's a great idea.
post #1724 of 2536
Very nice setup! Do you leave the behringers on all the time?
post #1725 of 2536
I really need to do the same with my QSC 5050 RMX, and hook up a DIY 12V trigger to it.
post #1726 of 2536
Dual Rythmik F15SE arrived earlier today. Nice to have some decent subs again.
post #1727 of 2536
Yikes.
post #1728 of 2536
Thanks. Part of me wanted to do the quiet fan mod to the amps and figure out how to mount them to the rear of the subwoofer enclosures, but I went with the basement idea instead. I think it'll be just fine this way.
I just set the amps up yesterday. Right now I am leaving them on 24/7, but that will be changing this weekend. A friend of mine is selling me his Niles AC-3 to allow me to trigger the amps with 12v. The problem is that I don't have any way to trigger the AC-3. My short term plan is to use a switched wall outlet with a 12v wall wart plugged into it. My future plan is to use a Niles MSU250 that has an IR 12v trigger on it. I just wish it wouldn't cost $250.00.
post #1729 of 2536
Thanks for the reply, i was wondering if you had a cheap solution worked out to power them on/off.
post #1730 of 2536
post #1731 of 2536
Originally Posted by Ysay View Post
Do I need to upgrade?
I just blew snot AND coke out of my nose! Good gawd that was funny!
post #1732 of 2536
Originally Posted by stgdz View Post
*sniff* someday, I will be able to do this...someday...and I expect the walls to be framed out as well but no drywall yet. I plan on doing the work mostly myself and it will make hanging out in my theater room that much more victorious!
this is awesome! Keep up the good work!
post #1733 of 2536
Hi to all,
Here's a picture of "MY" sub. It's a Dali Concept sub, completely sealed front firing with a 12" driver and an output power of 160 Watts. I decided on this model coz as you can see on the picture it nicely fits into the cabinet, moreover with this setup no WAF issues came up, ever! Thanks for looking at the attached photo!
post #1734 of 2536
Originally Posted by mogorf View Post
Hi to all,
.............Nice, very stylish wall unit, what are you using as mains? And exactly how old is this pic - I see VHS tapes (and player) ;-} ......
post #1735 of 2536
Thanks for your kind compliments!
I have a full set of Dali Concept series:
Front L + R: Concept 2
Center: Concept Center
Surround L + R: Concept 1
Front Height: Concept 1
Sub: Concept Sub
www.dali.dk (Made in Denmark)
You can see some more pix in my setup under my sig.
Yeah, I have a mixture of vintage gear and new gear.
Akai turntable (1978) with lots-a vynil from the past, Akai cassette deck (1978), Panansonic VHS video (1998), Denon AVR-2310 (7.1) and lastly Denon Blu-ray DBP-1611UD universal player. The picture was taken early this year.
post #1736 of 2536
How can this thread NOT be a sticky?
post #1737 of 2536
I can't tell what I'm looking at there. What kind of subs and speakers (more interested in the sub, though)? For reference, how big is the tv?
post #1738 of 2536
Too many awesome setups to comment on, so I'll go with one -
TJHUB, I really like those acoustic panels and you're right about your subs making your 58" (!!!) display look like a 32". Beautiful speakers as well.
I just got a subwoofer yesterday...Outlaw Audio LFM-1 EX:
post #1739 of 2536
His subs are DIY - dual opposed 15" AE speaker drivers each... like the submersive... speakers are Paradigm Sig S2's & C3. His Subwoofer build is linked in his post, kinda hard to miss that... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
Not sure on screen, I would suggest 50"
post #1740 of 2536
The TV is a 58" Samsung Plasma. Though, looking at it in the picture there, I really need a bigger TV. Just haven't seen any that I llike enough to replace the Sammy with since the departure of the Elites.
... the DIY subs are similar in size to the Epik Empire (18" W x 24"D x 22" H).
