AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › help asb-123 pick his new hdtv
post #1 of 6
pick one! i am sure that im done to these. I am leaning towards the 800
post #2 of 6
Big existing thread that compares the 800 to the 650. For the LCD you need to go to the LCD forum
http://www.avsforum.com/avs-vb/showt...hlight=800+650
post #3 of 6
Here is my choice and rankings:
1. 50PZ800
2. PN50A650
3. LN52A650
4. 52XBR4
Keep in mind, that all of these displays will present a wonderful picture. These are just choices and not favorites. All have strengths and weaknesses. If you have a brightly lit room LCDs would be ranked in higher priority. If you have controlled lighting the plasma should take top honors. Also if you throw the XBR4 it would only be fair to throw in the Pioneer 5020FD. That would be my choice over all of these displays.
Chris
post #4 of 6
^ What he said.
post #5 of 6
Panny 50" PZ800U for me. Fantastic set. Had it for 4 months, no probs.
post #6 of 6
here in canada the 800 is $3000 while the 650 is $2200. But, the 800 can be found on sale for $2600.
