AVS › AVS Forum › Video Components › Home Theater Computers › Best Nvidia chipset for AMD?
post #1 of 6
I want to know if any of you have had several motherboards with Nvidia chipsets if you can say which ones you found worked the best.
I'd prefer no on-board video.
post #2 of 6
There is absolutely no performance difference between the current NVIDIA chipsets for AMD (GeForce 8200/8300, nForce 750a SLI, nForce 780a SLI) except for some fancy features (i.e. SLI x8, SLI x16, support for EPP memory etc.). Summary:
- nForce 750a SLI = GeForce 8200 + SLI (i.e. the PCIe x16 link splits to x8,x8)
- nForce 780a SLI = 750a + nForce 200 (PCIe switch for x16,x16)
The older chipsets have no future (only HT 1000MHz; no support for the upcoming 45nm processors).
post #3 of 6
What about the 720a and 730a? Is it true that some of them don't have good on-board sound?
post #4 of 6
The full name of GeForce 8200/8300 is "GeForce 8200/8300 and nForce 730a" (it's a single chip, but is called as if it were a two chip solution). nForce 730a/720a is a cut-back version of "GeForce 8200/8300 and nForce 730a" without onboard video. Summary is here.
The HD audio controller built in these chipsets are exactly identical. The difference appears only with third-party audio codecs (ALC888, ALC889a etc.), but only when you use analog, there is no difference if you use digital (S/PDIF).
BTW if you use a Radeon card, it has its own HD audio controller (7.1 ch with HD 4xxx), independent of that of the chipset. GeForce card lacks it so that it supports only S/PDIF pass-through from the onboard audio codec.
post #5 of 6
Well,I was kind of wondering if anyone was going to leave any comments about stability and lack of issues etc. I'm not completely happy about the Asus M3A78-EM not "reacting well" with the on-board 3200 and even not running like it should with the 4670. It worked well with an X1650XT and I read someone put an 8800GT in it and it worked flawlessly. (I did everything in the world like swapping hardware and looking at BIOS settings, trying different drivers.)
I just want to find a chipset that wouldn't be considered "flaky".
EDIT: I read here:
http://forums.pcper.com/showthread.php?t=459059
that some people like the GIGABYTE GA-M750SLI-DS4.
Any user comments for this one?
post #6 of 6
Many people in this forum including me are using a GeForce 8200/8300 mb/Phenom and are very happy with them. Personally I didn't find anything flaky.
