Spectrum folding (not sure where foldback came from) was discussed a lot in papers I read extensively to do with digital standards conversion a good few years ago.
One paper I particularly remember reading - which may be of interest is here : http://www.bbc.co.uk/rd/publications..._1984_20.shtml
It doesn't specifically use the phrase spectrum folding - though others I read (can't find them online) did. (They used it in relation to non-ideal interlaced systems - such as non-anti aliased cap gens causing issues. Actually - here is one discussing "spectral overlap" http://downloads.bbc.co.uk/rd/pubs/reports/1984-14.pdf Fig 8 (iii) shows the issue quite nicely )
The quoted paper pre-dates CCD broadcast cameras (and probably is mainly concentrated on non-CCD telecines as well) - and is very much based on 70s and 80s "real world" sources rather than what we have today.
However the discussion about the diagonal vertical vs temporal graph (Fig 29) that is required for interlaced content (rather than the square variant that would be allowed for progressive - then called sequential) shows the issue. If you are outside the triangle section of that ideal filter - you are in the realms of ambiguity in an interlaced signal (you simply can't absolutely know whether the information is vertical temporal or vertical spatial information)
It is a good 20 years since I put my Fourier and Laplace stuff to good work - and that paper is 25+ years old. However the fundamentals are sound.
Without some examples of what appears on a screen, the concept is very tenuous. There are hints we're saying the same thing: The Kiening tutorial paper I cited shows aliasing (figs. listed) by comparing thickened/darkened lines, at higher frequencies (blurring details), in a line-burst pattern that gradually increases in frequency, although he's just showing horizontal aliasing. It also appears that vertical aliasing could apply to progressive images, too, from inadequate filtering, or in static images--unless one limits the context to interlaced 'spectrum folding' with motion. -- John
The basic fundamental spectrum folding is fine detail flickering when content isn't vertically filtered (usually where the source is film or progressive video). That is where vertical spatial information has been folded into the temporal domain - and thus appears to flash/flicker (i.e. is altering in the temporal domain) rather than appearing static.
Similarly - the converse is true. Content moving vertically at certain speeds can appear to be 'distorted' in vertical resolution terms if not properly filtered. If you imagine a picture made up of fine black and white alternating lines. If this moves up the screen at certain speeds at a certain resolution, you might only ever sample the black lines or the white lines. The temporal information has distorted the spatial. Or if a similar image was static, you might sample all the black lines in one field, and all the white lines in the next. You'd therefore end up with an image that flashed black and white - the worst case scenario where the vertical spectrum has entirely folded into the temporal. If you pre-filtered by line-pairing with a line offset, you'd end up with a continuous grey field - so would have lost vertical resolution, but gracefully, and without folding into the temporal spectrum. Obviously worst case - but it illustrates the point?
Whether there is flicker on the de-interlaced image displayed progressively will depend on the de-interlacing approach - and assumptions as to the source - but these are assumptions. (AFAIK there is no 25pSF/30pSF vs 50/60i source signalling in use these days - PALPlus included it to improve chroma decoding - though MPEG2/H264 encoders may make assumptions in their encoding streams they aren't explicitly signalled in the HD-SDI sources AFAIK - and would break-down where pSF and i sources are on-screen at once)
