post #1 of 1
This HD1000 has always worked fine taping digital signals or analog from the tuner. I recently connected a video signal to the line input. It shows up on the line output only if the recorder is off or the digital input is selected. When line is selected I can only get the solid blue screen on the line output. In record it will not record the analog line input by selecting line or digital input even with the digital connector removed. Is there any set up menu that can make this work? Thanks John
