AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › EchoStar TR-40 recording
post #1 of 3
I have an Insignia standard cecb. The longest it stays on is 4 hrs., therefore not allowing me to record something after it turns off. Will the TR-40 allow me to record something after it has turned itself off when I'm at work? Or is there something I can do to use my Insignia for timer recording? I don't want to start panicking yet!
post #2 of 3
On all these CECBs, you should be able to find an "Inactivity Timer" that by default is 4 hours. You should be able to disable this. Start looking in your manual / menues.
post #3 of 3
Use existing topics.
This thread is locked
