If you have a media server, what transfer speed do you get when copying large files (>1GB) into or from the server? I've seen transfer speed of 80 to 100 MB/s in this forum, while my server only manages to get an average of 12 MB/s when copying files to it.
I have an nForce4 (Abit AN8-SLI), 1GB RAM, 1.8Ghz Athlon 64+, built-in gigabit ethernet (which I think is on PCI-e bus, but not 100% sure). My gigabit switch is SMC EZ 8508T which supports jumbo frame.
So my question is: to achieve high transfer speed without enabling jumbo frame, do I need to switch to a server class motherboard, like the Intel 3200 series, or can I just put in an Intel Pro/1000 PT PCI-e card?
As long as the system is correctly configured for gigabit, you should get gigabit speeds, hardware permitting. Jumbo frames keeps coming all too often, but understand that jumbo frame support is all about "efficiency" i.e. lower CPU usage at the SAME throughput rates, it doesn't magically make your transfers any faster.
