AVS › AVS Forum › Display Devices › Display Calibration › YCbCr 4:4:4 or 4:2:2 with new PS3 "Chroma upsampling"?
post #1 of 11
Hi!
In the TV models that have the option of select YCbCr 4:4:4 or 4:2:2 HDMI video input, which is recommended to select with the new chroma upsampling of the PS3?
post #2 of 11
http://uk.playstation.com/help-suppo...ma-Upsampling/
During BD (BDAV) and DVD playback, a technique known as “chroma upsampling” is now automatically selected based on the movement of objects within the video content and then applied to enhance images in the content.
Usually, video content that is provided as digital broadcasting or video media compresses colour information to keep the data size small. Using a chroma upsampling technique, the PS3 system then processes the compressed colour information and applies it to the video content so that the content appears more vivid and sharp on the screen.
For Blu-ray Discs, this feature is only available when playing discs that are recorded in BDAV format. BDAV is a Blu-ray Disc video format. Generally, when video content is recorded on BD-R or BD-RE media using a Blu-ray Disc recorder, the content is recorded in BDAV format. You cannot use this feature on video content recorded in BDMV format, including most commercially available BD video software (BD-ROM) now on the market
Basically this feature will not work with comercially recorded BDs. It will only work with DVDs (unless you burn your own BDs).
post #3 of 11
I think this should be implemented on pre - recorded BLU RAY...I never actually realised that DVD players and BLU RAY players? upsampled the chroma from the disc's native compression of 4:2:0 to 4:2:2 as standard..So whats the difference with this one..does it benefit image quality greatly anyone know??? For example viewing on both 8 and 10 bit panels...
post #4 of 11
From what I've seen, it's more like the PS3 applies a smart interpolation filter to chroma before upsampling it, so far I haven't seen any adverse effects.
post #5 of 11
OK, so does the PS3 upsample BLU RAY video (BDMV)to 4:2:2 anyway?
post #6 of 11
Yes, it has to. On the other hand, it all will end up 4:4:4 eventually no matter what when it gets back to RGB. If you force it to output RGB, then it's outputting 4:4:4. Or the TV will go back to 4:4:4 when it moves back to RGB. So this doesn't inherently get you anything new, it just moves the location of where this is happening, and may or may not change the quality of how it's handling the chroma samples, which realistically is not a big deal at all.
post #7 of 11
Actually it improves it a lot for stuff like those big red WARNING letters at the start and other places with large blocks of solid color where it usually gets all pixelated.
post #8 of 11
That means that your TV wasn't doing it right.
post #9 of 11
Well then, I guess i've been watching those big WARNING letters in faulty tv sets for years, interestingly enough the chroma option of the PS3 fixes my TV, and unfixes it if I turn it off.
post #10 of 11
I noticed these parts of a disc do look exceptionally bright and clear...
post #11 of 11
Wow..i never understood this...I always assumed that DVD players outputted 4:2:0 video...but there is no setting option that allows you to get standerd 4:2:2 upsampling in PS3 is there?? I saw there was a setting for video type output (HDMI) and i normally select AUTOMATIC as opposed to just the other singlular options such as RGB or YCbCr .
