Originally Posted by
penngray
IMO, If I want a great amp I would buy a separate amp and not worry about the amp that is put inside a processor box. That goes for any AVR and not just the 805.
I disagree with this. There's no reason a great amplifier can't be inside a receiver, and as far as I can tell, the 805 has just such an amplifier.
penngray
Also the posted ratings above are an apples vs orange comparison HK does a different rating with their watts and the industry believes it to be more accurate...I would suspect the TRUE difference in Watts here is probably less then 30W and if you have to realize that 100W vs 130W is pretty meaningless in the world of SPL....BOTH are limiting and both introduce more distortion because you are closer to clipping.
I will agree that the apparent difference between 100w and 130w is miniscule and likely not noticeable to most people. However, I disagree that they are rated differently. These are both taken from their respective specification lists on the web sites:
Onyko TX-SR805: "Front L/R 130 W + 130 W (8 ohms, 20 Hz-20 kHz,
0.05%, 2 channels driven, FTC)"
AVR354: "Continuous Average Power (FTC) per Channel : 75 Watts per channel, 20Hz - 20kHz, @ <0.07% THD, both channels driven into 8 ohms"
Where is the difference in rating? Now if you're arguing that the AVR354 actually exceeds it's rating, and puts out 100w/channel at the same 0.07% THD, that's fine. But I couldn't find any review stating such.
penngray
IMO, If we want to discuss power and dynamic SPL ranges then we need to START with requirements like 200W/ch anything less is a compromise of a properly design HT system.
I completely disagree with this. Any assertion of power requirements for a 'properly design HT system' (whatever that may be)
must take into account both room size and speaker efficiency. To say that you need a minimum of 200w/channel completely disregards those with small rooms or efficient speakers, or at best, asserts that you need higher than THX reference levels. In an average sized home living/theater room situation (2000-3000 cubic feet), speakers with a 93+dB efficiency at one watt don't need anywhere remotely near 200 watts to achieve THX reference levels - not even one quarter that much. And that's assuming all speakers are running full range, which we all know is almost never the proper way to setup the system. Remove bass from the front and surround channels, and actual power requirements drop even farther. Add this to the fact that THX reference level, in my experience, tends to be much too loud in a home environment - most prefer to run -5dB to -15dB below reference, and you need significantly less power still.
All that said, even a system which cannot reach THX reference levels, either as a result of speaker limitations or amplifier limitations, can still be properly designed - as long as the goals for the system are met.
