Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
Dr. No AVC 1:49:50 29,177,131,008 42,877,355,998 35.42 29.32 DTS-HD Master 5.1 3050Kbps (48kHz/24-bit)
DISC INFO:
Disc Size: 42,877,355,998 bytes
Protection: BD+
BD-Java: Yes
PLAYLIST REPORT:
Length: 1:49:50 (h:m:s)
Total Bitrate: 35.42 Mbps
Description:
FILES:
Name Size Length Time In Time Out
00001.M2TS 29,177,131,008 1:49:50.458 0:00:00.000 1:49:50.458
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 29319 kbps 1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 3050 kbps 5.1 / 48kHz / 24-bit / 3050kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
Dolby Digital Audio French 448 kbps 5.1 / 48kHz / 448kbps
Dolby Digital Audio English 224 kbps 2.0 / 48kHz / 224kbps
Dolby Digital Audio Spanish 224 kbps 2.0 / 48kHz / 224kbps
SUBTITLES:
Presentation Graphics English 34 kbps
Presentation Graphics French 0 kbps
Presentation Graphics Spanish 30 kbps
Presentation Graphics Spanish 0 kbps
CHAPTERS:
Number Time Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:02:50.670 28,058 kbps 42,115 kbps 00:00:33.367 36,576 kbps 00:00:29.363 35,854 kbps 00:00:24.358 146,280 bytes 423,728 bytes 00:01:37.180
2 0:02:50.670 0:03:43.015 34,487 kbps 36,960 kbps 00:03:11.066 35,447 kbps 00:04:00.407 35,247 kbps 00:04:27.476 179,801 bytes 400,690 bytes 00:04:05.245
3 0:06:33.685 0:03:08.230 33,114 kbps 36,497 kbps 00:07:02.505 35,325 kbps 00:06:58.460 35,181 kbps 00:06:53.538 172,644 bytes 315,910 bytes 00:09:32.822
4 0:09:41.915 0:06:44.946 28,842 kbps 35,828 kbps 00:09:59.849 34,876 kbps 00:09:58.848 34,562 kbps 00:09:54.302 150,369 bytes 291,757 bytes 00:12:27.997
5 0:16:26.861 0:02:33.987 30,338 kbps 36,389 kbps 00:17:24.794 34,032 kbps 00:18:52.798 33,686 kbps 00:18:47.460 158,168 bytes 303,501 bytes 00:18:54.258
6 0:19:00.848 0:03:05.644 31,045 kbps 38,020 kbps 00:19:26.999 35,084 kbps 00:19:33.255 34,931 kbps 00:19:27.333 161,857 bytes 425,147 bytes 00:20:47.288
7 0:22:06.492 0:02:25.979 27,583 kbps 35,980 kbps 00:23:03.299 32,028 kbps 00:23:02.756 31,270 kbps 00:23:03.090 143,805 bytes 409,944 bytes 00:23:22.276
8 0:24:32.471 0:02:11.131 28,478 kbps 34,935 kbps 00:26:42.643 29,970 kbps 00:24:39.353 29,683 kbps 00:24:36.934 148,473 bytes 407,064 bytes 00:26:43.644
9 0:26:43.602 0:01:44.521 31,971 kbps 36,428 kbps 00:26:55.531 35,169 kbps 00:26:51.610 34,620 kbps 00:26:47.564 166,684 bytes 410,201 bytes 00:26:49.650
10 0:28:28.123 0:02:54.132 28,820 kbps 33,269 kbps 00:28:28.832 32,097 kbps 00:31:14.706 31,766 kbps 00:31:11.078 150,254 bytes 317,712 bytes 00:28:39.593
11 0:31:22.255 0:04:45.327 27,024 kbps 32,866 kbps 00:35:57.030 31,102 kbps 00:31:35.769 29,718 kbps 00:31:30.931 140,893 bytes 287,084 bytes 00:32:42.252
12 0:36:07.582 0:01:31.675 30,930 kbps 34,846 kbps 00:37:38.298 32,497 kbps 00:37:34.294 31,701 kbps 00:37:29.289 161,256 bytes 327,778 bytes 00:37:39.299
13 0:37:39.257 0:03:38.802 29,916 kbps 36,291 kbps 00:38:52.747 35,386 kbps 00:38:48.743 35,035 kbps 00:38:49.077 155,969 bytes 338,265 bytes 00:37:48.850
14 0:41:18.059 0:03:20.158 26,114 kbps 37,833 kbps 00:44:36.841 30,832 kbps 00:41:26.776 29,787 kbps 00:41:27.402 136,147 bytes 321,860 bytes 00:44:36.549
15 0:44:38.217 0:02:06.460 29,690 kbps 35,624 kbps 00:46:41.382 32,840 kbps 00:46:39.213 31,063 kbps 00:44:56.694 154,792 bytes 271,715 bytes 00:45:36.651
16 0:46:44.677 0:01:34.219 31,302 kbps 34,860 kbps 00:48:17.436 33,304 kbps 00:48:13.432 32,867 kbps 00:48:08.552 163,195 bytes 296,611 bytes 00:47:05.489
17 0:48:18.896 0:03:05.352 32,579 kbps 36,719 kbps 00:49:24.628 35,236 kbps 00:49:54.742 34,949 kbps 00:49:49.153 169,853 bytes 425,953 bytes 00:50:39.912
18 0:51:24.248 0:04:04.327 29,819 kbps 36,793 kbps 00:51:36.260 34,761 kbps 00:51:32.214 33,294 kbps 00:53:00.302 155,463 bytes 457,756 bytes 00:51:37.136
19 0:55:28.575 0:03:21.535 28,544 kbps 32,728 kbps 00:55:30.911 31,015 kbps 00:55:55.936 30,489 kbps 00:55:55.310 148,815 bytes 280,998 bytes 00:57:30.822
20 0:58:50.110 0:03:05.811 23,021 kbps 28,952 kbps 00:58:59.494 27,396 kbps 00:59:14.885 26,447 kbps 00:59:14.009 120,023 bytes 281,366 bytes 01:01:53.084
21 1:01:55.921 0:06:12.205 30,159 kbps 36,261 kbps 01:03:29.097 33,881 kbps 01:04:32.660 32,930 kbps 01:04:27.739 157,233 bytes 335,850 bytes 01:05:23.086
22 1:08:08.126 0:04:31.729 32,365 kbps 37,771 kbps 01:10:21.551 35,461 kbps 01:11:46.052 35,219 kbps 01:11:46.135 168,738 bytes 481,951 bytes 01:12:14.372
23 1:12:39.855 0:02:38.075 28,366 kbps 35,056 kbps 01:14:55.658 34,089 kbps 01:14:55.157 31,652 kbps 01:14:55.157 147,889 bytes 349,342 bytes 01:14:59.286
24 1:15:17.930 0:02:46.375 24,895 kbps 30,442 kbps 01:16:38.219 27,528 kbps 01:16:35.132 26,310 kbps 01:16:30.294 129,793 bytes 280,283 bytes 01:15:19.140
25 1:18:04.305 0:02:50.128 29,900 kbps 35,306 kbps 01:20:04.174 33,588 kbps 01:20:00.337 32,864 kbps 01:19:58.627 155,883 bytes 283,425 bytes 01:20:05.009
26 1:20:54.433 0:05:34.167 29,140 kbps 34,021 kbps 01:21:02.608 32,323 kbps 01:20:59.855 31,646 kbps 01:20:59.855 151,923 bytes 319,969 bytes 01:21:07.529
27 1:26:28.600 0:07:32.160 29,559 kbps 34,696 kbps 01:33:53.419 32,980 kbps 01:33:39.781 32,348 kbps 01:33:37.487 154,107 bytes 297,831 bytes 01:33:48.122
28 1:34:00.760 0:05:02.511 27,221 kbps 36,399 kbps 01:38:57.557 34,661 kbps 01:38:57.682 34,057 kbps 01:38:20.853 141,919 bytes 330,057 bytes 01:38:55.805
29 1:39:03.271 0:04:02.158 29,500 kbps 36,082 kbps 01:39:45.271 34,887 kbps 01:39:48.482 34,690 kbps 01:39:45.021 153,799 bytes 311,176 bytes 01:39:13.364
30 1:43:05.429 0:02:13.592 29,915 kbps 35,788 kbps 01:44:39.690 34,516 kbps 01:44:37.938 33,940 kbps 01:44:32.975 155,964 bytes 278,746 bytes 01:43:31.831
31 1:45:19.021 0:02:11.173 28,452 kbps 36,228 kbps 01:47:10.591 32,204 kbps 01:47:06.629 31,164 kbps 01:47:05.002 148,337 bytes 358,028 bytes 01:46:05.818
32 1:47:30.194 0:02:20.265 28,203 kbps 37,858 kbps 01:49:13.422 35,839 kbps 01:49:09.460 35,437 kbps 01:49:04.455 147,040 bytes 344,390 bytes 01:49:14.882
STREAM DIAGNOSTICS:
File PID Type Seconds Bytes Packets Bitrate
00001.M2TS 4113 (0x1011) 0x1B 6590.46 24,152,907,191 131,358,752 29,319
00001.M2TS 4352 (0x1100) 0x86 6590.46 2,512,647,624 14,676,253 3,050
00001.M2TS 4353 (0x1101) 0x81 6590.46 184,532,992 1,029,760 224
00001.M2TS 4354 (0x1102) 0x81 6590.46 184,532,992 1,029,760 224
00001.M2TS 4608 (0x1200) 0x90 6590.46 27,834,497 159,068 34
00001.M2TS 4609 (0x1201) 0x90 6590.46 24,393,956 139,834 30
00001.M2TS 4355 (0x1103) 0x81 6590.46 369,065,984 2,059,520 448
00001.M2TS 4356 (0x1104) 0x81 6590.46 184,532,992 1,029,760 224
00001.M2TS 4610 (0x1202) 0x90 6590.46 124,247 724 0
00001.M2TS 4611 (0x1203) 0x90 6590.46 157,390 910 0
