OK Sports Fans ... Calibration tip #1
I did experiment with the service menu calibration of the auto iris.
*** Warning ***
Before we begin, understand that diving into the service menu has risks. The risk that you could change a value, and having not written it down, be unable to go back. So, when going into the service menu to make adjustments, ALWAYS write down the factory settings your are about to alter.
*** End Warning ***
Use the following remote commands to enter service mode
ENTER ENTER <- ENTER then answer YES to the question asking if you want to enter the service mode.
You will note at the bottom of the main menu DEVICE has appeared in the blue border. Go down and click DEVICE.
You will see a number of sub-menus open.
For this adjustment, you will go to the OTHER menu.
Use the UP/DOWN arrow keys to scroll thru the menu. Adjustments to values are made with <- -> keys.
Look for:
(01) IRIS ADJ (0)
(02) OPEN REG (725)
(03) CLOSE REG (347) Change this to 140. It takes awhile to click your way down, so be patient.
Don't worry about the other settings.
What does this change? The auto iris is triggered by luminance values. OPEN REG controls at what value the iris become fully open. CLOSE REG controls at what value the iris starts top open.
You might note on low APL scenes (dark scenes) there is a difference between running MANUAL IRIS set to MIN and running the AUTO IRIS. The Manual IRIS will make the scene darker. By lowering the CLOSE REG, the same low APL scene under AUTO IRIS can be lowered to a similar darkness.
Is there a down side? Yes, but it is minor. As scenes work their way up from lower APLs the IRIS is made to open, but not as quickly as when the CLOSE REG was set to the factory setting. However, the degree to which lower APL scenes are made darker by this change is not linear through the entire luminance range. Rather, by the time the scene luminance level hits 30 IRE (in analog terms) the effect of the change is eliminated and the AUTI IRIS tracks normally to the point at which it becomes fully open. Make sense?
Give it a try. Here is a good test. Take the IronMan BD and click through the few chapters markers, which start with the following images...
1) woman in bed, dark room
2) stirring pot by fire
3) backgammon board
?) airplane in front of Stark Enterprises
Notice how each of the scenes look under the factory auto iris setting. With the change in place, look at the same scenes again.
1) is nicely darker
2) is modestly darker
3) is very slightly darker
?) is full brightness
You can see how much you are changing the scene's black level by going up to the 1st item in the OTHER service menu, (01) IRIS ADJ, and changing it from (0) to (1) and back to (0). You need to leave this setting at (0).
The next step if you like what this adjustment changes, would be to tweak the GAMMA curve just a bit. I believe it is possible to adjust the GAMMA curve to help raise a bit of the lower APL range without bringing absolute black back up. I have not played with this as it is something I'd like to do with test patterns while taking some readings. However, switching to GAMMA 1 is a pretty good 1st step to try.
Also, I just arrived at the CLOSE REG 140 number by eye. A better number might be determined by taking measurements to confirm how dark you would like the target low APL scenes to be. 140 seems good for now.
I watch a bit of the Troy BD with these changes in place, and while I enjoyed better blacks in very dark scenes, other low-mid, mid, mid-high & high APL scenes still looked excellent.
Let me know if you have any questions.
RJ
PS... in the service menu, you will see a SAVE feature at the bottom of the main menu list. You will have to commit to saving the changes other wise they will be lost and all changes return to factory settings on shut down.
*** Warning ***
*** End Warning ***
Look for:
(01) IRIS ADJ (0)
(02) OPEN REG (725)
3) backgammon board
1) is nicely darker
RJ
