AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Audyssey MultEQ causing bass distortion
Audyssey MultEQ causing bass distortion - Page 2
post #31 of 32
Hey man, I was having the same problem with my earthquake supernova mkV 10" , had it hooked up with a Y conector and was getting distortion with audyssey during the Iron Man cave scene. I got rid of the y connector and that got rid of almost all the distortion while using the audyssey EQ. I dont know if this is a fix for my specific sub but it made a big difference. also by doing this I was able to raise the volume on the sub getting the subs amplifier to do more work and have more control over the it. Woth a try if you have it wired up that way. smile.gif Ive got a vid of the sub before I got rid of the Y conector.
http://www.youtube.com/watch?v=Ui6o9sCiMxU
Hope this helps.
post #32 of 32
The quality of the bass was reduced by removing the Y conector, maybe turning off the audyssey EQ is your best bet after all.
Edited by Andrew Rothman - 2/12/13 at 2:12pm
