AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Oppo 980H vs. Pioneer DV-410V-k vs. Harman DVD-48
post #1 of 7
I am mostly interested in sound quality.
I have read everywhere owners raving about the sound quality of the Harman Kardon DVD-48 and of the Oppo 980H. What abou the Pioneer DV-410 which is by far cheaper than those and easier to buy?
Thanks for reporting your experience.
post #2 of 7
Your using analog I take it?
post #3 of 7
Analog connection no but analog material yes, I do listen it often. I still listen CD although more and more often I am going towards mp3 eoncoded at 256kbps (cannot tell much difference from original analog).
All but the HK have a USB port, which I plan to use often.
I have a HK receiver, if that matters.
post #4 of 7
I love my OPPO
post #5 of 7
I recently got the 410 and although there was an improvement over the picture there was a more noticable improvement over sound to my Marantz SR5300 via coax.
post #6 of 7
If your using digital connections, there won't be any difference. All the player is doing is passing the raw mix on to the receiver. It isn't doing any decoding.
post #7 of 7
Blacklac. are you saying thet every player will sound the same when using digital connections??? Glad i didnt spen anymore money !!!
  Back to Forum: DVD Players (Standard Def)
