I ordered this Computer Soundcard -
link to search thread at AVS - for my Russound-based whole house audio system:
Audiotrak Prodigy HD2Link
Potential purchase site:
link
Prodigy HD2 shows the latest technology in high end audio playback for audiophile users.
Prodigy HD2 supports 192 kHz at 24-bit with a sensational dynamic range of 120dB(a) for playback - no other hardware in this price range provides this high level of output quality. Even better: the hardware is equipped with 3 OpAmps on sockets, this makes it possible to swap and exchange the OpAmps based on specific requirements.
Prodigy HD2 is a Low Profile PCI card, shipping with a metal bracket for a conventional PCI slot and with a bracket that allows the installation in Low Profile slots - this makes Prodigy HD2 perfect for media center and home theater solutions where small PC cases are used.
The included driver software is providing perfect compatibility (ASIO, GSIF, WDM) under all current Windows versions including Windows Vista 32-bit & 64-bit, offering high performance and low latency operation. DirectWIRE 3.0 support in the driver allows you to virtually patch your digital audio sources internally between different software applications running at the same time.
Features
- PCI audio interface based on VIA VT1721 (Envy24HT-S)
- PCI card supplied with standard and low profile metal bracket
- 24 bit / 192kHz playback (analog & digital)
- 24 bit / 96kHz recording
- high quality AKM AK4396 120dB(a) S/N ratio DA converter for extremly high quality 2 channel audio playback via RCA output connectors (5Hz - 40kHz frequency response)
- triple OpAmp design for audio output with three high quality Fairchild NE5532 OpAmps on separate sockets (can be exchanged for tuning & customization)
- headphone output with 1/8" connector routed via JRC4580 dual OpAmp
- analog line input with 1/8" connector via AKM AK5353/7 102dB(a) S/N ratio AD converter (20Hz - 40kHz frequency response)
- optical S/PDIF digital output following IEC-958C standard, can be used for stereo audio playback (PCM) and multichannel streams from such sources (AC-3 or DTS data)
- EWDM driver based on ESI technology for all current Windows Versions
Computer (desktop, home)
- Cyberpower
CPU: Intel Core i7 920 @ 2.67 GHz
Audio: Creative SB X-Fi Extreme Fatal1Ty (not working ??? -- having intermittent problems with output. Unclear of problem exactly)
Video: ATI Radeon HD 4870
Monitor: Del 2408WFP
Memory: 6 GB
OS: Windows Vista Ultimate - 64 - SP1
Use:
1) headphone output to computer monitor speakers
2) RCA output to Russound house sound amps
I'm now thinking about the Squeezebox...
Squeezebox Duet or
Squeezebox Touch
--- other Touch links --
Slashgear,
Gizmodo,
AVForums
DABDig (specs and more pics):
Page includes FCC report and specs:
4.3 LCD panel with capacitive touch screen
High quality analog and headphone outputs (24bit/96k)
Optical and coax S/PDIF outputs
802.11g wireless
64MB SDRAM & 64MB NAND flash
SD card slot & USB host connector
Internal speech-grade microphone and speaker - sound effects and preview
IR sensor for remote control
Ambient light sensor for dimming screen at night
IR proximity sensor for detecting user approaching
Digital temperature sensor for home automation
Audiocircle (specs and pics)
Technical Specifications
o Audio formats:
-MP3, FLAC, WAV, AIFF, WMA, Ogg Vorbis, AAC, Apple Lossless
-WMA Lossless, APE, MPC and WavPack supported through transcoding
-Some formats may require additional software installation
o Internet radio
-Support for MP3, Ogg Vorbis, and WMA formatted Internet Radio streams
o Wireless interface
-True 802.11g wireless networking
-Support for 802.11b and 802.11g routers and access points
-One-touch setup (with compatible WPS-supporting routers)
-Supports WPA Personal, WPA-2AES, and 64/128-bit WEP encryption
o Ethernet interface
-Connects to any 100 Mbps or 10 Mbps network (with Auto MDX)
o General:
-USB host connector for accessing music and photos via USB drive or USB key
-SD card slot for music and photos
-Supports sampling rates up to 24 bit / 96 kHz
-Stereo analog (RCA), headphone jack, digital optical, and digital coax output
-4.3-inch 24-bit color LCD with capacitive touch screen
-Ambient light sensor to adjust display brightness according to environment
-Infrared proximity sensor to detect presence
Mike
