Bought the Xonar DX and Sennheiser HD 555 headphones right.
SO hear wa going now nah.
Install everything and first thing I went to was windows sound control to look for the tone adjustment. You know that advanced tab where you can raise treble and bass slider but its usually graved off and not selectable with cheap onboard sound.
So I running excited they man to raise these 2 sliders all the way just I had done with my Audigy 2 ZS. LOW and behold it has NONE!!!!!
Now I am forced to use the garbage Equalizer to raise the bass and heights. Mind you I hate to use EQ is just distorts the sound the best way I find to raise bass and treble is adjusting that tone slider. Its hard to explain it but its as if it Raises the bass volume instead of adjusting a retarded Equlizer.
Now mind you this 116db card is so clean even with the Xonar EQ and WMP EQ bass all the way up thos MOFO actually sounds rather clean and impressive. But it can in no way touch my old Audigy 2 ZS. This is bad for headphones.
Beware people the Xonar DX is the worst card on the planet for any headphone. I am totaly disappointed and disgusted in Asus for only focussing on 35 times cleaner than onboard audio and not giving an option to adjust the bass. I wish I had my old Audigy 2 ZS back now but the crap had dreaded driver issues I always hated creative for that.
