Originally Posted by afrogt
You might not have your BD80 set up correctly. It may be decoding the TrueHD internally and sending to your receiver. Make sure the BD player is outputing bitstream, not PCM.
It works fine either way but if you want the light to come on, make sure the player is outputting bitstream from HDMI.
Or make sure you selected the TrueHD track on the disc. Many times it doesn't default to the TrueHD audio. I think The Dark Knight or Ironman is that way.
Thanks for the help!! I did go into the DVD menu and looked under LANGUAGE section.......there it was.......ENGLISH DOLBY True HD!! DUH!!
Now that I switched it on, played the Matrix Blu Ray DVD.......and........WOW!
Unreal. I sure was missing out! Seriously, I almost wept a few tears! Now that is what The Matrix should sound like!
I LOVE this Panny SA BX500 receiver........it is soooooo LOUD, CLEAR & CRISP! My Polk Monitor 60 fronts NEVER sounded so good. Now, I need to get my rear speakers upgraded and see what else I was missing!!
NOTE TO SELF: make sure you switch to Dolby True HD in the LANGUAGE section on your Blu Ray DVD!!!!!
