I am wondering how I can get at least 5.1 to be sent to my sound system. Here are my specs:
-ECS A780GM-A mobo (AMD 780G chipset w/ Radeon HD 3200 integrated GPU)
-ATI Radeon HD 3470 PCI-Express GPU
-NOTE: I use AMD's 'hybrid crossfire' that uses both the integrated GPU and discrete GPU
-AMD Phenom X3 8750
-Sony X10S blu-ray drive
-Sony Bravia 40V4100 LCD TV (1080P)
-Sony HT-CT100 sound system
-Cyberlink PowerDVD 8 Ultra (supports blu-ray, DTS-HD, etc)
I connect the system via HDMI to the Sony sound system which forwards the video over HDMI to the TV.
I can only get the system to send 2-channel PCM output to the sound system. The sound system is a 3.1 setup so I would at least like to send 4-channel PCM or Dolby Digital/DTS/ProLogic to it (the sound system supports both methods). I am worried primarily about blu-rays since that is when I want this type of sound.
Also, the mobo has an HDMI port and the discrete card comes with a DVI to HDMI dongle. I currently have the HDMI coming out of the mobo's HDMI slot since this is the way hybrid crossfire makes it work.
Is there a way to get my HTPC to send more than 2-channel PCM output with my current setup? (Through PowerDVD, or setting up the HTPC config differently, etc)
If not, what would be the best way to achieve this? (buy a new video card, buy a sound card, etc)
Thanks for your help.
-AMD Phenom X3 8750
