Originally Posted by oraclation
I put on 2 hrs and here is my initial criticism in order of importance:
--The black level floor is good, but not as impressive as I expected
--Brightness is borderline in Cinema1,2,3
--Slight color uniformity issue, more red on the left half of screen (hope it improves after ceiling mounting upside down)
--Sharpness is just adequate for 1080p
--Hard to tell for sure, but convergence appears only minor
PS3 BD>HDMI>AE3000 (15ft throw)>110" wide 2.35 Carada BW
FYI-I'm comparing to my Mits HD1000U 720p DLP w/800hrs
I'm using a 129" wide 2.37:1 screen... 1.16 gain.
I also found the Cinema modes a little dim and I liked the colors in Normal mode the best out of the box. That could change with some tweaking. Black levels seemed very good, though I have nothing to compare it to.
Brightness was also noticeably dimmer when switching between 16:9 and a zoomed out 2.35:1.. though after watching for a few minutes you get used to it.
I also noticed that out of the box, the sharpness is turned all the way down. I have not tried turning it up yet.
I haven't noticed any color uniformity or convergence issues... though in the case of the latter, I have no idea what I'd be looking for.
I had to do quite a bit of tweaking to get rockband2 to play smooth and in sync. I'm still trying to decide which frame creation setting (1, 2, off) and which frame processing (fast, normal) combination I like best.
More impressions to come later.
