AVS › AVS Forum › Display Devices › Display Calibration › I am trying to figure out what these advanced adjustments are on my projector
post #1 of 2
In addition to the normal video calibration adjustments, my Marantz VP-8600 DLP projector has an additional menu that the call the Fine Menu. For what it is worth, it only seams to be accessible if you are using a HD source. The slider choices are as follows:
R.Gain = to adjust the white color temperature on red
B. Gain = to adjust the white color temperature on blue
R. Bias = to adjust the black color temperature on red
B. Bias = to adjust the black color temperature on blue
What would I use these for, and how would I use them?
Greg
post #2 of 2
What they are for is adjusting the color temperature- just as their descriptions indicate. How you use them is described in the various 'FAQ' and 'sticky' threads at the top of this section of the forum.
