Skyrim is $30 this weekend on Steam. For those of you thinking about moving over to the PC version for better framerates and fidelity, let me entice you a bit.
http://www.youtube.com/watch?v=hTg-U8atbR0
This video is made but some sort of nub, but it does eventually get to the good part. You can pretty easily copy your 360 savegame to a USB flash drive, then open that savegame on your PC. At that point you can extract the important section and load it up in the PC version of Skyrim. I just moved to Skyrim PC and can report success in retaining my progress from the 360 version. I don't know if there will be weird issues later or anything, but currently everything looks to be in order.
Now I'm off to check out the mods.
