AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › *New* Western Digital - WD TV HD Media Player
*New* Western Digital - WD TV HD Media Player - Page 3
post #61 of 9960
Please forgive my ignorance in asking this question:
I do not currently own an HDTV (aside from my PC monitor @ 1440x900).
What would happen if I plug this WD unit into an SDTV via the composite outputs and then play a 720p or 1080p/1080i file?
Is there a limit on the output of the composite cables of 480p/480i? Will the media player simply downscale the HD output to fit properly in full screen on a 480i/480p TV? or will the display be out of whack and zoomed in/out looking because of the higher resolution?
I would appreciate it if someone would plug one of these into a SDTV and test some HD clips to report how the downscaled output looks.
post #62 of 9960
Originally Posted by R Johnson View Post
NTFS for files > 4GB?
I have seen users confirm it does allow all different file formats. Again, from a marketing perspective, WD is launching this to sell external harddrives, so it is in their interest to allow as many differnet file formats and be able to play codecs/containers that house the largest file sizes.
post #63 of 9960
Admittedly I haven't had much time to test it out yet, but it was downscaling 1080p content for my 720p television. I would imagine it does the same over composite, but it's probably a bad idea to assume. I'll test it out later today when I have a chance if no one else has already answered the question.
post #64 of 9960
anyone try an external ext3 drive?
post #65 of 9960
Agreed. But the WD site and literature I've seen does not specify which file systems are supported.
post #66 of 9960
Any idea which media processor it uses?
post #67 of 9960
Over at Macworld, a WD product manager commented on formats it could play. While not exhaustive in his reply, the one thing that pulled me to buy this toy is the AVCHD support.
I'll be getting one tonight and plan to test it tomorrow to see what it can do with my HD files. I'll post results tomorrow.
post #68 of 9960
I believe it's a sigma chip
post #69 of 9960
Does this box not have a digital audio out except for the HDMI connection? Please tell me there is one.
post #70 of 9960
Link: http://www.macworld.com/article/1365...irst_look.html
The article says there's a digital optical output.
post #71 of 9960
The pictures of the back with all the inputs on the WD product page shows an optical out.
http://www.wdc.com/en/products/products.asp?driveid=572
post #72 of 9960
Sure looks like an optical out, doesn't it. I'm going to pass by BB today and check it out.
post #73 of 9960
As a matter of fact I have mine connected to a SDTV via composite and I played a 720P .mkv file and it appears to just downconvert it and it played just fine. It was letterboxed since I was playing it on the 4:3 TV.
I still need to try it on my 60" Sony SXRD R60XBR1 HDTV and my Dell 24" 1920x1200 2408 LCD panel that has HDMI input.
post #74 of 9960
which one? Will a daring person open and find out? The version of the sigma makes a difference.
post #75 of 9960
Alright, I got one. BB@$99.
It's great! Played 11Gig MPEG2 recorded on PC of the air ATSC file On NTFS drive - no problem, both, 720p and 1080i.
Plays VOBs, looks like it wall automatically combining main movie files into one, skipping menus. Chapter skip does not work.
Picture looks fantastic on my 9' analog projector in 1080i.
Now, to cool you off, the not so great stuff:
- On my LCD quantization noise is plain annoying. It's not the best panel, but DVI to HDMI from my nVidia PC alway was smooth. I guess WD quantizing video output at 8 bit. TV's scaler just magnify it. (Quantization was not noticeable on analog projector.)
- Hard Drive power never turned off, even after unit itself is. It even never send a command to put drive into sleep or spin it down. You have to eject and unplug drive every time!
- Unit gets hot. Not horribly but more than typical other products.
- It locked-up when I pull USB drive without pressing eject first. Require cold restart.
- Searching long files not so pleasant, with max x16 it takes a while to FF to get to the second half of 2 hour flick. No other way to search long files.
- maybe just my TV, but 1080p output mode was breaking, loosing pixels on the bottom, cracking sound and fuzzy OSD. Don't mind this one yet but please verify?
Other that that, so far, it is good and recommended!
Cheers!
post #76 of 9960
Just picked one up a few hours ago. Does indeed have an optical out, and it does passthrough DD 5.1. Haven't tested DTS 5.1 yet. Going to try a Blu-Ray .m2ts right now and see if it works (not expecting anything, but it would be great!)
Other than that, in the couple files I've tested so far, it's GREAT. This thing plays back 1080p x264 .mkv files like they're nothing.
post #77 of 9960
That's it, be back in 1.5 hrs
post #78 of 9960
SuperUser:
What about subtitles when playing VOB files? Is there a button on the remote to turn subtitle on and off?
post #79 of 9960
anyone figure how to add thumbnails to the mkv files? i love this thing! i finally got one of my friends to switch to mkvs and skip bluray.
post #80 of 9960
A few complaints I have so far (pretty minor, but kind of annoying nonetheless):
The media library SUCKS. I've disabled it and switched to list mode, and it's better. I'd recommend doing the same when you first hook it up.
1080p24 would be nice. Not sure if this may be achievable later via a firmware update or not.
I'm not sure, but it seems like this device is adding some kind of sharpening without any way to turn it off. Edges look very "enhanced", something I do not like to see. Again, this isn't really a deal breaker, and not extremely noticeable, but I do notice it. Perhaps it's not sharpening, but it has to do with its scaling algorithm it uses for 720p -> 1080p conversion. I don't notice this sharpening effects with 1080p files, and I notice it very much with 720p files, so it's got to be something along those lines. Anyone else notice this?
post #81 of 9960
There's a remote button ("Options") to switch subtitles, but it doesn't work with .VOBs.
post #82 of 9960
it only shows subtitles with srt files. maybe they can fix that with future updates
post #83 of 9960
I stopped by BB and picked one up. I'll try it this evening. Am I correct in assuming that I can load a ripped DVD (VOB files) to a thumb drive, and play it through the device?
post #84 of 9960
Is the output resolution fixed, or is there a setting for it to be dynamic based on the file resolution (i.e. a 720p file is output at 720p, a 1080p file is output at 1080p). If it has some sort of dynamic output resolution setting, that may fix your problem (but at the same time rely on your display's scaling for 720p->1080p which may be better or worse).
post #85 of 9960
It has no dynamic resolution switching, therefore I leave it at 1080p60. Yes, I agree, my display would do a MUCH better job at scaling the 720p files to 1080p, but at this time with current firmware, the WD player will only output the resolution it is told to output. When I get home, I'll switch the native output to 720p and see if my 720p content looks better.
post #86 of 9960
If convenience of switching the output resolution becomes an issue, you may want to see which affect is worse, upscaling 720p or downscaling 1080p... not an ideal solution, but if 1080p content downscaled to 720p takes less of a hit, that might be the way to go. How much content you have in each resolution might also make the decision for you. Good luck!
post #87 of 9960
I went ahead and bit on this. I will pick it up after work and see how well it works for me to replace my MediaGate player.
post #88 of 9960
A couple of things we need to get cleared up...
1) does it do DTS pass through?
2) what is the max bitrate for smooth playback of H264/MKV...? or what is the bitrate of the videos you guys are testing? some HD rips are over 10mbit.
3) can it display subtitles embedded in MKV files?
post #89 of 9960
I will test the first two when I get home. I don't know about question 3, as I don't have any MKV files with embedded subtitles.
post #90 of 9960
ok so this thing is pretty awesome, especially for $100. it plays my 720p and 1080p mkvs better than my pc. will prolly pick one up for the bedroom also. this thing is pretty much what ive always wanted someone to develop. its not perfect but its pretty darn close really. the pic it great on my pioneer and the sound is hooked directly to my yamaha with no problems.
i know this is avs but lets try not to get TOO technical and tear this thing apart with tech spec mumbo jumbo. best 100 i spent in a while.
i Like to collect cartoons from the 90"s and its so much nicer having it all archived on a Hard drive rather than a bunch of dvds, that u have to keep swapping.
Now under settings it has an "Auto" for the options under "resolutions". i would assume that means it changes automatically for the source, i could be wrong though.
i couldnt get it to play WMVHD movie i have, though. they were 1080p also.
bottom line... GO BUY THIS WHILE ITS ON SALE!!
