No subtitles for VOBs. Looks like it will ignore all and any additional data included in DVD stream. It will just play VOB end to end. It will however allow you to select different audio tracks. It supposed to support "Subtitle- SRT (UTF-8)".
More specs: wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=2697
Display Resolution: It will output in selected format only, no matter what source material is.
In "Auto" mode resolution will match HDMI display data channel. In my case when set to auto it will output 768P even when there is no such thing in the menu.
Cheers!
Cheers!
