Hi there, my first post - i see you are some knowledgable people on DLP projectors so hope i can get some help.
So im after a projector and saw that i can buy one for approx £450 (Optoma HD65) which looked promising. MANY....MANY reviews have given the HD65 a healthy thumbs up.
My main use will be for XBOX 360 gaming in Hi-Def, and for occasional normal quality DVDs via the 360. was going to hook my freeview up to it but after reading on this forum and other places of relevance, decided against this due to bulb life and general inconvienience of switching lights off etc...i still have a 32" HDTV for other general TV use.
My situation/uses are:
1) White wall for projection of image (will not invest in a screen just yet)
2) potential proj uses: XBOX 360 gaming / NORMAL DEF DVD movies via 360
3) Would you guys strongly advise FOR a screen solely in respect to the HD65?
So my questions are basically
1)Is the HD65 the way to go for my first projector?
2)How long can i (realistically - upon your experiences) expect the bulbs to last (i see its between 2000-3000 hours)
3) how big of an image will i get given the max distance the projector can sit will be approx (9FT 9') - EDIT i calculate around 80" diag?
4)How about angle viewing? Say if someone is sat on the other side of the room but not facing directly forward to the wall - what will the pic look like?(sounds a bit stupid ques now i wrote it out, but please answer anyway!
Please could you give me some much required help, i will eagerly await your responses as i really want to get going with viewing/playing Gears of War 2 (next week) on a bajillion inch screen.
)Please could you give me some much required help, i will eagerly await your responses as i really want to get going with viewing/playing Gears of War 2 (next week) on a bajillion inch screen.
If this is correct - how would i work around this?
