My wife is having a built in and she asked..........
a) If I could have the subwoofer put on the other side of the room (behind if your sitting watching TV) I figured this is a "no."
b) If the contractor makes a cabinet big enough to hid it so you can't see it.
I think I have a Bic-100.
These were rear ported also. Room is 20'X13.5'X8.6' and the front subs are not actually in the corners, just close to them. I would not expect to ever see any benifit of them being corner loaded inside of a cabinet. The results I heard/felt was lots of pressure from the enclosures in the back of the room, and lots of flanking up my back wall. Placing them inside a cabinet is a last resort. Fortunately, I found a different solution than to doing this. "enclosed 1" is front subs, 'allsubsenclosed2" is all subs including the rear ones in the enclosure and "allsubscorner" is a sub in each corner without an enclosure. The only adivise I have really is to try something else, or get a subwoofer desinged to go in a cabinet if yours is not.
she’s just been awkward. It would rattle like hell ask if she wants it rattling and buzzing.
