AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › HDPVR Support on the Mac (HDPVRCapture)
HDPVR Support on the Mac (HDPVRCapture) - Page 36
post #1051 of 1190
I am not personally familiar with using the Playstation 3. Are you trying to use the HDPVR to digitize the output of your PS3? Or, are you somehow trying to use the PS3 as a bridge between the HDPVR and your Samsung? How do you receive your HD programming: over the air, cable, satellite?
post #1052 of 1190
No, I would just like to capture the footage from my PS3. I thought I could capture what was being displayed on the TV with the PVR? If anything Im using the PVR as a bridge between the TV and the PS3, if that makes sense?
I want to use the PVR to record what the TV is displaying, and the TV is displaying HDMI video output.. it just seems like the PVR doesn't isn't picking up this signal and therefore captures nothing.
Im under the impression that I may have to find the correct "channel" for the PVR to capture what I want?
post #1053 of 1190
Unless I am missing something here:
You did not answer how you receive your TV content (over air, cable or satellite), but it does not matter.
The HDPVR would have to be connected to the video output of your cable or satellite receiver. If off-air, you would probably need a digital tuner, such as Elgato's Eye TV.
post #1054 of 1190
10.5.8
Hmm, that's not right. I'll look into this.
post #1055 of 1190
A *LOT* of people capture content with HDPVRCapture from the PS3.
Check the basics:
You do see your serial number in the top left hand corner of the application?
If you have SageTV or EyeTV installed they grab the hardware and keep it locked / inuse even if they're not using it. Remove these applications if you have them.
Make sure your PS3 is NOT set to 1080p, try 720p for test purposes. Select the correct audio and video inputs in HDPVRCapture. Without doing anything other than selecting your inputs, video should be detected by HDPVRCapture and shown in the lower left. If not, something is fundamentally wrong.
Side note: Make sure your audio cable is connected, you can't capture without audio.
Best,
- Steve
post #1056 of 1190
Hey guys thanks so much for the help, I've finnaly figured it out. It was to do with the wires and the channel it was on.
The wires seemed to be plugged into the wrong sockets..the wires on the top row needed to be put in the bottom row and visa versa. Strange though, the pictures which are shown on the HD PVR Capture program are actually in the opposite sockets to mine. The the TV had to be put onto the "Component" channel. I then changed the resolution to 720p and it worked...then played around with it a bit and got the resolution to 1080i . Im now very satisfied and happy.
Now im just testing the video quality on Youtube and hopefull have the best quality i can.
Thanks guys, much appreciation for all the help, great community.
post #1057 of 1190
Hi Everyone. First time poster
How can I get my macbook or imac to recognise the Hauppage HD PVR. Shows as connected in about this MAC on highspeed usb. Connection is from xbox360 to PVR via component then then mac/imac. Trial version of HDPVR says hardware not found. I know the PVR works as I have it working in windows 7 via bootcamp using the supplied Avermedia software with no problems. Would prefer to use osx Snow Leopold though.
Any ideas or solutions gratefully received.
Also after the solution of how to capture in game voice chat. I can capture game sound fine.
Mark..
post #1058 of 1190
Suddently I am getting the following error message with h264ts cutter:
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
"Index was outside the bounds of the array."
Continue does not work for me...
I just want to chop a 15.5Gig 4 hour file in half, so that I can burn it to two DVD-D/Ls in Blu-Ray format...
Anybody know what is going on here? Any alternatives? Thanks!
post #1059 of 1190
I recently purchased the Haupauge 1212 HD PVR and HDPVRC version 2.5.7 to go with it on my MacBook Pro 2.2GHz, 4MB memory, 800MHz bus with Mac OS X 10.6.2. I'm still getting acquainted with it and have run into some issues. I've been reading through this extensive forum and apologize if I'm bringing up questions that have been previously answered. If these have already been addressed in this forum please point me to the posting number. The issues and questions I have revolve around scheduling with TitanTV. From Steve's FAQ, Scheduling and automatically Recording, I see the following instructions: "How do I schedule a recording using TitanTV? Using your*favorite*browser navigate to TitanTV.com and create yourself an account. Set your zipcode and hardware to a Hauppauge PVr350. Now, when you next navigate to the TV grid you will see a red record button for each show. Click this red button and your browser will download a file called program.tvpi'. Do to your downloads folder and Open the file. HDPVRCapture will instantly*recognize*it and confirm the scheduling details with you. Click OK to schedule the recording."
I created my personal account and went through the settings, but do not see anywhere an option to set my hardware to a "Hauppauge PVr350." Has this changed? If not, where do I go to set this in my TitanTV account settings?
When I log into my TitanTV account I bring up my TV schedule in my browser and see the program details popup when I hover over a program listing. Within this popup I see a record option, which I select and it proceeds to put a "program.tvpi" file in my downloads. When I go to select "programs.tvpi" in downloads I get the following:
Pop-up: "The document "program.tvpi" could not be opened."
If I first select HDPVR Capture as my active application on my desktop and select the "iCal" tab and click inside "A Summary of the iCal Schedule" I can then open the "program.tvpi" file and add it to the schedule. Is this correct behavior where I have to first click inside the summary? For the scheduled entries the correct date appears, however the time always displays as 00:00. Is this the bug Steve refers to in posting #994? Also, how do you edit the entries added to the schedule? I've tried the edit menu and a variety of command sequences without any success. I know command n allows for a new entry, but it doesn't allow me to edit an existing entry. Is there a way to delete existing entries? I've tried command x, delete, and drag-and-drop to the trash without any success. I see the calendar, HDPVR Recordings, was automatically created in iCal. Are the scheduled entries supposed to show up in this iCal calendar? I don't see them there. Thanks for your time and patience answering my questions.
post #1060 of 1190
I found posting #481. Based on this the details I listed above are the bug Steve made mention of in OS X 10.6. I look forward to receiving Steve's fix for this when it is available. It looks like the FAQ needs to be updated too so the step of entering the model of PVR is removed.
post #1061 of 1190
Hello all
I am close to giving this up altogether and then I found this thread which seems helpful to a point.
I'll relay my story and see if anyone has any solutions (even if they are blindingly obvious) as I'm stumped.
I bought the HD PVR unit with the sole intention of recording game footage from my ps3 to load onto Youtube.
I am using a 2ghz intel core duo Imac running 10.5.8. The first problem I discovered was that it doesn't have usb 2...only 1.1. Am I right to think then that the HD PVR will not hook up with my mac?
That problem, aside, I turned to my older G4 that I have. This I was able to fit a USB 2 PCI card which helped although I am now sure that the mac itself is far from powerful enough to deal with the files. I've tried the demo (HDPVR Capture) and it appears to sluggishly work and produces .m2ts files but these are 4 or 16kb so clearly not 2 minutes of recording.
I am also getting no picture on the mac showing what is being recorded. Should there be one?
Barring buying a pc to run the supplied software with no trouble at all, any help as to where I'm going wrong. I'd like to buy the full Capture software, but until I can get the demo to work I'd rather not gamble.
Thanks in advance for reading this tale of woe hahaha
post #1062 of 1190
Originally Posted by station6 View Post
Hello all
Steve will reply with more detail, but some thoughts:
An Intel iMac will definitely have USB 2 on the back ports; the extra USB on your keyboard,if at all, will be USB 1.1.
An older G4 will not have the power to capture nor play the files.
Go back to the Intel iMac with core duo and figure out why their is a USB problem ...
post #1063 of 1190
Okay went back to the iMac, connected it all up and hit record. I get the blue top light on the unit and the red one on the front come on but nothing else seems to happen other than navigating around the Capture menu constantly requires a long amount of time.
According to the profiler, the mac only has 12mps on the usb...hmmm
Edit: okay the mac does have usb 2 so I can scratch that off the list haha
post #1064 of 1190
Email me directly, my contact details are on the blog.
post #1065 of 1190
Once the entries are made you can edit or delete the schedules directly in iCal itself, from my mac in your mobileme shared calendar group.
The ical view in HDPVRCapture is really a summary/report of what's found in your calendar itself and isn't really targeted at offering full edit support.
It sounds like the FAQ needs a spruce up after TitanTV modified a few things. I'll add this to the todo list.
Thanks for the feedback.
- Steve
post #1066 of 1190
YOu should be able to capture content on the G4 and a USB2 card. THe 'monitor video while recording' option isn't going to work well for you but capturing should work perfectly well.
Last I tests on a G3 (10.4) with USB1.1 (and the bitrate intensionally kept relatively low < 7Mbps) the capture went fine. Make sure you're capturing to the internal HD of the G4. Try lowering the bitrate, perhaps the USB2 cards isn't really delivering USB2 speeds.
If you still have issues then let's discuss.
- Steve
post #1067 of 1190
For test purposes, cold boot everything, start HDPVRCapture on your G4 and set the option to max bitrate 2mbps, min 1mbps,
What happens then?
- Steve
post #1068 of 1190
It has the power to capture but certainly not playback.
Yes, a great idea.
post #1069 of 1190
OK, so it's Steven moaning and groaning time again!
Over the last 6 months or so I've repeatedly complained that I'm not getting notifications via email for updates to this thread from the AVSForum.com mail system. For example, the last notification I have from from Michael's posting on or around Feb 4th.
I happened to login today in response to a recent AVCNoodle posting and figured I'd double check 'just in case' the HDPVRCapture thread had any activity .... sure enough, thread questions I wasn't aware of!
Nothing in my spam box, nothing in my inbox.
My time is precious (as is the readers time), the mail system let's me focus that time without distraction. Mail updates is a valuable feature for me (and the other readers).
Is their a known mail issues? Anyone got thoughts on this?
- Steve
post #1070 of 1190
Hey Steve, a while back you mentioned adding picture cropping during record as a possible new feature. What's the status on that one? I've got some 4:3 content that would benefit from it. Thanks, I'll also send an email in case the forum glitch you mention above pops up.
post #1071 of 1190
I love my tivo series 2, but not the monthly fee. But that's the user experience I'm after.
So I have the following hooked up:
-- HD PVR, with component inputs, and component outputs and audio going to my receiver. I receive audio and video fine.
-- Mac Mini with Firewire 1 tb drive attached. The digital output of the Mac runs into the HDMI on the TV, bypassing the receiver.
I apparently have to look up the channel, switch to it, then record with PVR Capture/Eye/Sage to my Mini?
I then can watch it (assuming I have the right codecs) back on the TV via WD TV Live.
This seems like a lot of steps. Also seems as if I'm missing something that makes all this easier. But in terms of user interface, is there Tivo and then all the rest or is there Tivo and a bunch of roughly equal software packages which utilize HD PVR/WD TV Live in some combination? Or am I tilting at windmills?
/john
post #1072 of 1190
Hey guys I just have a small problem I can't seem to figure out.
I bought the HDPVR and capture program a few months back, and both work great. The only problem I seem to have is the video getting slightly pixelated at times. The raw footage after capturing looks fine, but once I try to edit the video it gets all messed up
EX:www [dot] youtube [dot] com/watch?v=rYEzgcxy0O8
(sorry I can't link directly, but i don't have 3 posts yet)
Am i doing something wrong when I export or capture? Sorry if I'm putting this in the wrong place but I didn't know where else to ask. Thanks for reading.
-Crazed
post #1073 of 1190
If the raw video looks fine, it is the editing function that is causing the problem, not the capture.
What do you use to edit; and are you transcoding after editing?
post #1074 of 1190
Well I use either premiere or after effects to edit the footage. And forgive me for not being as technical as I should be, but transcoding? All i know is I export the video as an .mov, usually with whatever the default exporting settings are.
post #1075 of 1190
Has anybody else been experiencing problems using the VLC Preview while capturing?
Since the last update, when I hit record, VLC fires up, shows the preview for a few seconds and cuts out.
Ive tried various builds of VLC, and still get the same thing
--Other than that I am loving this HDPVR and HDPVRCapture ---
post #1076 of 1190
Just want to add my experience with the HDPVR and HDPVRCapture software and how I am using the setup. It has been fantastic so far. With all of the things I read on AVS and Amazon regarding issues with the hardware and the lousy Windows software, I am amazed by how great all of this works on a Mac. The entire experience has been plug-and-play and I practically didn't need the manual.
Steve's software is great. Not only does it work flawlessly but it shows the maturity gained from all the great feedback in this thread. Little things like the manual timer, the indicator that the hardware is receiving a signal, etc. make it very easy to use. So I can contribute in some small way, here's my work flow if others need to do the same kinds of tasks. I am just archiving shows (mostly Saints' football-related) from my D* HD DVR to AVCHD disks burned on standard DVD media for playback on a BD player.
I simply play a show/game through the HDPVR and capture it. I then add the m2ts file to a Blu Ray project in Toast. I can add up to about one hour on a standard DVD. Toast provides a simple but effective editor so I can take out commercials. There is no transcoding so the whole process is quick and simple. The burn only takes as long as any conventional DVD and the resulting video quality is excellent. The only minor complaint I have is the poor quality of the AVCHD disk menus available through Toast. They look very amateurish. But it's an easy compromise for such an outstanding video result that can be created so quickly.
Thanks to Steve and everyone on this thread for adding to my arsenal of video tools.
post #1077 of 1190
i just recently got the hdpvrcapture and everythings good its just not converting files to play on my quicktime its playing on this software i have that is only a trial and i am not able to play them enless i have them to auto snyc to itunes so is there anything i can do....and i do not have the option to select to use the vlc need help???
post #1078 of 1190
HDPVRcapture still cannot see the hardware on my imac under Snow Leopard.
Any ideas anyone?
Mark..
post #1079 of 1190
Im new to HD pvr and hdpvrcapture.. but playing with it for a short time I am liking it so far... only problem is the lack of imovie but other then that so far so good. as i play with it a little more maybe I can help others out also.
thanks Stoth for the great program
post #1080 of 1190
I've been having some problems with color.
Every deinterlace program I've tried to use with files from HD-PVR capture has mangled the color somehow.
That's the original.
These are players viewing the file after I've deinterlaced it.
Additionally, when quicktime exports a frame the opposite effect happens - it becomes much darker.
I've used more than one deinterlace program, so I don't think it's a problem with deinterlacing.
Is there something strange about the way HD-PVR writes gamma information? There's something on page 28 about removing the gamma tag I don't entirely understand.
EDIT: Those screenshots aren't actually deinterlaced, I just ran them through the program with deinterlacing set to "none" to see if it made a difference.
  Back to Forum: HTPC - Mac Chat
