AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › HDPVR Support on the Mac (HDPVRCapture)
HDPVR Support on the Mac (HDPVRCapture) - Page 29
post #841 of 1190
Hi Steve,
Thanks for your response.
I'd love to hear how this works, as would many other people. Do you have an URL for that specific converter?
Have a look on ebay using the search "HDCP HDMI to Component Audio Video Converter Transcoder". Says can de-crypt HDCP encrypted streams. Will have to see how long this works with Sky HD if its popularity goes up!
I don't think this is possible. That being said I'll email a couple of other people in the UK and find out if they see this issue also. I'm wondering if I can flag (even if it's a manual process) WSS in the recording. I'll have to look into the spec.
AFAIK, flagging doesn't work with DIVX/XVID, .H264 and the modern codecs. This is why HDTV captures by SD XVID boxes (which you'll find on the web) are 555x312 and strange resolutions like that. They have to reflect the aspect in the frame-size itself. Players will not reliably 'respect' the aspect flag for these streams. Similarly, if you asked Nero to encode a widescreen DVD to H.264, it will scale the frame-size itself. In the Mpeg-2 world, they used PAL/NTSC 4:3 resolutions, but then used the flag to indicate WS.
Anyway, nowadays, they broadcast a lot of SD channels in WS aspect. When I captured them using the Hauppauge USB2 PVR in Mpeg-2, I could post-process the WS flag into the stream without re-encoding.
I intend to use the HDPVR equally often for recording SD channels (HD channels are still few). For this use, the re-scaling to WS aspect on-the-fly is quite crucial. As a device, the USB2 PVR Mpeg-2 could never display or encode WS natively. But, this is not the case with the HDPVR, as it obviously handles the WS aspect of HD sources. It can also choose resolutions. So, maybe there would be a way to tell it to choose a 720x405 resolution for SD sources? Just thinking.
Eeek, you also might want to switch away from composite inputs and use svideo for SD content, you'll be much happier with the video quality.
Oh, no, that I'm using. I just used 'composite' to mean old 'analog SD'...
Tatha
post #842 of 1190
Will Collier: I think the multiple conversion thing is a real bug related to how I'm dealing with quicktime. It should be an easy fix.
Unrelated: Have you looked at the newer Hauppauge firmwares recently for the HDPVR? http://hauppauge.lightpath.net/softw...5.6.0_beta.zip
It has some nice fixes of your capturing from FIOS and also has the March 2009 fix for the issue where the HDPVR can corrupt it's own flash ram, making the box unusuable. (You'll nee to install the windows driver and connect your HDPVR once to force a firmware update inside the HDPVR).
post #843 of 1190
I was completely unaware of that, thanks. I assume you recommend doing the upgrade?
Drop me a line when the next release version is ready. I'm planning to plug it at my blog, want to make sure there's a stable 5.1-passthrough version available for purchase when I do.
post #844 of 1190
Steve, a little follow-up here:
I haven't seen the choppy playback thing again since I posted the first time. Unless you've seen it yourself, chalk that one up as just a weird couple of days on my Mini.
On the other hand, here's something I just replicated: when I do an automatic conversion after an encode, I get the all-tracks-to-Mono thing again in the audio file. Confirmed that again today after a ~90 minute recording. Without resetting anything, I did another recording (~50 minutes) without converting, then manually dropped it in the conversion window afterwards. Perfect conversion that time, all the surround channels were right.
I did the firmware update this morning (in a Boot Camp partition), went without a hitch.
post #845 of 1190
Fair enough.
I remember that you'd seen this in the past then the issue went away for you, although we didn't know why. In some respects it's good to see the issue raise itself again.
So the automatic conversion after recording isn't doing 5.1 passthrough properly, but manually always works? and you see this 100% of the time?
Perfect.
- Steve
post #846 of 1190
- Steve
Yes and yes. I think this has been going on all along, and I didn't catch it because I didn't realize the all-mono bug was only happening on automatic conversions. What I'd been doing was make an encode on the Mini at my TV (thinking it was glitched for conversions), then taking the m2ts file upstairs to my desktop, and coverting it there. Found out last week that the Mini will convert just fine so long as that conversion is done manually after the fact.
The desktop isn't situated where I can make an encode+conversion there to check it out, but I feel pretty secure in saying the bug is in the automatic conversion step.
post #847 of 1190
I have a free weekend so I'm going to fix this today along two or three other things pending for 2.5. Expect -b3 this weekend and a gold release if things are looking good.
post #848 of 1190
FYI
The next build of HDPVRCapture will support channel changing with external apps. example args are:
Code:
 -c  -d  -f
A template changer script:
Code:
#!/bin/bash
# HDPVRCapture channel changer example script (www.steventoth.net)
while getopts ":c:d:f:" opt; do
        case $opt in
        c)
                CCCHANNEL=$OPTARG
        d)
                CCDURATION=$OPTARG
        f)
                CCFILENAME=$OPTARG
                echo "Invalid option: -$OPTARG"
                echo "Option -$OPTARG requires an argument."
                exit 1
esac
done
echo "On `date`, changing to channel $CCCHANNEL for $CCDURATION seconds, recording to filename $CCFILENAME" | tee -a /tmp/changer.log
exit 0
post #849 of 1190
Hi,
v2.5.0-b3 is available for download here: http://www.steventoth.net/hdpvrcaptu..._v2.5.0-b3.zip
Mostly bugfixes. Full details in the release notes here:
http://www.steventoth.net/hdpvrcaptu...easeNotes.html
I'm reasonably happy with this build so if we have no major issues in the next few days then it will be released for everyone mid-week.
Will Collier: Due to STB issues I had problems repro'ing reliably the 5.1 channel assignment, although I made a number of changes which should help.
- Steve
post #850 of 1190
Hi,
- Steve
Success! Just did a 55 minute recording with automatic conversion, and the audio file is correct.
As Doug McKenzie said to his brother Bob, "Thanks, eh."
post #851 of 1190
Will Collier: Thanks, positive feedback.
If it still looks good for you in a couple of days then I'll push the button and roll this out to everyone.
- Steve
post #852 of 1190
Read thru most all of this thread, thanks for the great work.
I have been a SageTV user (on a Dell server, W2K & XP) since version 2 and had planned to switch to their Mac version on a Mac Mini until they told me sorry, NO support for IRBlaster, NO EPG support for my provider (US Mainland only).
Discovered this software via a link in the SageTV Mac forum!
My question is, does HDPVR Capture support the SA/Cisco series of STBs? ie: the IPN430 or IPN330? Also used by Uverse.
post #853 of 1190
Kind words, thank you ... and welcome ezeitler!
Does is support the STB specifically? I don't know because I don't maintain that level of detail. What I can say is that the app has 12 distinct SA complete IR codesets for cable and 12 for satellite. This is pretty good STB coverage across (I suspect) much or all of their product line. To the best of my knowledge these works with all SA boxes on the market.
The HDPVRCapture demo doesn't let you exercise the IR so you're in a limbo. That being said my pledge to you is this: If you become a customer and IR doesn't work, and if you're willing to use the windows software to Learn your STB buttons, I'll inject your learned IR information into the Mac app - completely adding support for your STB. This is easily done.
As for the rest of the functionality, feel free to download the demo and give it a spin.
- Steve
post #854 of 1190
Head's up... if there's a Microcenter store near you, they're closing out the 1.83GHz Mac Minis for $349. In-store pickup only. That is a SMOKING price for a great Mac HTPC (and yes, it works great with HDPVRCapture).
post #855 of 1190
From the Release Notes:
"Known Issues: .mp4 files don't play on the MP3 (Workaround: play the native .m2ts instead)"
You mean PS3, right?
post #856 of 1190
Correct, I'll fix this typo.
- Steve
post #857 of 1190
Hello all,
I'm trying to troubleshoot a problem I'm having with the recordings from HDPVR Capture. I'm capturing HD DVDs using the component outputs on an LG BH100. I noticed recently that the record light will go off for a second or two and then come back on arbitrarily. This tends to happen multiple times during a recording.
This obviously introduces glitches into the captured stream, and I'm not sure if it's the Hauppauge device, the player, or the software.
Any insight would be greatly appreciated.
Something else to note. I noticed some odd popping & cracking sounds from the Hauppauge unit when I first started recording with it (it's less than a month old), so my suspicions currently lie with the unit itself.
post #858 of 1190
toho: You're not the first to see issues like this. We've discussed problems like this in the past.
First let's establish some basics:
1. When you record, the drop down UI (first line) shows the model, rev and date. What info do you have.
2. I assume the issue only occurs when you capture with SPDIF, and not with analog inputs? (test this to rule out a few things).
3. Is the HDPVR connected directly to your mac using the Hauppauge supplied USB cable?
update:
4. Does this happen with specific BD titles or many different titles?
- Steve
post #859 of 1190
- Steve
It's done, v2.5.0 has been released. Details on the blog: http://www.steventoth.net/blog/
As always, many thanks to everyone here at AVSForum who have tested and/or given feedback.
- Steve
post #860 of 1190
Well, I wonder if I've reached a point of no return... I tried updating to the 1.5.6 firmware and now I get all 3 lights (blue, red & yellow) constantly and HDPVR Capture no longer sees the device.
post #861 of 1190
toho: Call Hauppauge tech support.
post #862 of 1190
I have been reading up on the HDPVR and the software involved. I am a little confused though so hopefully I can ask this question and get some clarification.
If I get a HDPVR and the SiliconDust HD Homerun, can I record over my network to my iMac which is down the hall and away from my TV setup? I know I will need to buy the app from stoth to work on OS X 10.5, but do I also need something like EyeTV for this to work?
stoth and the community, thanks very much!!
post #863 of 1190
You're welcome!
I can't speak to the HDHomerun side of things, I suspect you'll need EyeTV for this. Perhaps another member can comment.
In terms of HDPVRCapture you can certainly run it on a machine that's closest to your cable box, have it control your STB via IR and record your TV shows in HD, but watch the resulting recordings in another room over the network.
You have a couple of ways of doing this but I'd suggest you start with the basics. That is, store the recordings local on the machine next to the STB then access them over the network. They'd be viewable Plex or via iTunes (*with a small/fast automatic conversion step) or a whole host of other applications depending on how your expose the network share on your STB Mac.
- Steve
post #864 of 1190
You're welcome!
- Steve
Thanks Steve! I ordered a HDPVR and HDHomerun device today. Hopefully it comes by Friday so I can play around with it this weekend. I don't have a system near my TV, but might get a Mac Mini in the near future to connect to my plasma and add to my network. I could also bring my iMac into the main room, so we'll see what happens.
post #865 of 1190
Hey Steven,
First I would really like to say thank you for taking the time and the effort to write this program. I am a long time PC user but don't like booting into Windows on my MacBook Pro.
I'd love to purchase your software, but I am a bit concerned because I'm having an issue with the demo version. When my Hauppauge 1212 isn't on, the program runs fine. When the 1212 is on, it quits unexpectedly almost immediately.
Any ideas what could cause this? I'm using a 17" MacBook Pro unibody (Jan/Feb 09) and have the latest version of Leopard installed. I'm also running the latest firmware on the 1212.
Any and all help would be much appreciated! Here is my error report:
EDIT: I noticed that the serial number that pops up in the program is different than the one that's in my system profiler in OSX, unless I'm not remembering correctly. I'll have to look again.
Code:
Process:         HDPVRCapture [179]
Path:            /Applications/HDPVRCapture.app/Contents/MacOS/HDPVRCapture
Identifier:      net.steventoth.HDPVRCapture
Version:         ??? (2.5.0)
Code Type:       X86 (Native)
Parent Process:  launchd [74]
Interval Since Last Report:          562359 sec
Crashes Since Last Report:           23
Per-App Interval Since Last Report:  7504 sec
Per-App Crashes Since Last Report:   11
Date/Time:       2009-06-27 22:13:40.594 -0400
OS Version:      Mac OS X 10.5.7 (9J61)
Report Version:  6
Anonymous UUID:  AAF7AE22-9190-45BB-86C0-A0B4AE131BBB
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread:  0
Thread 0 Crashed:
0   ???                                 0000000000 0 + 0
1   com.apple.iokit.IOUSBLib            0x13f6b7e0 IOUSBInterfaceClass::interfaceControlRequest(void*, unsigned char, IOUSBDevRequest*) + 112
2   net.steventoth.HDPVRCapture         0x000113c6 recv_control_msg + 156
3   net.steventoth.HDPVRCapture         0x000114de cmd_get_fwdetails + 68
4   net.steventoth.HDPVRCapture         0x0000fddc usb_get_signal_status + 108
5   net.steventoth.HDPVRCapture         0x000080f7 -[hdpvrController handleSignalStatusTimer:] + 196
6   com.apple.Foundation                0x94f78517 __NSFireTimer + 279
7   com.apple.CoreFoundation            0x961c5ac5 CFRunLoopRunSpecific + 4469
8   com.apple.CoreFoundation            0x961c5c78 CFRunLoopRunInMode + 88
9   com.apple.HIToolbox                 0x9003328c RunCurrentEventLoopInMode + 283
10  com.apple.HIToolbox                 0x900330a5 ReceiveNextEventCommon + 374
11  com.apple.HIToolbox                 0x90032f19 BlockUntilNextEventMatchingListInMode + 106
12  com.apple.AppKit                    0x9388cd0d _DPSNextEvent + 657
13  com.apple.AppKit                    0x9388c5c0 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
14  com.apple.AppKit                    0x938855fb -[NSApplication run] + 795
15  com.apple.AppKit                    0x93852834 NSApplicationMain + 574
16  net.steventoth.HDPVRCapture         0x00002dd2 _start + 216
17  net.steventoth.HDPVRCapture         0x00002cf9 start + 41
Thread 1:
0   libSystem.B.dylib                   0x9443146e __semwait_signal + 10
1   libSystem.B.dylib                   0x9445bdcd pthread_cond_wait$UNIX2003 + 73
2   com.apple.ColorSync                 0x92eb445c pthreadSemaphoreWait(t_pthreadSemaphore*) + 42
3   com.apple.ColorSync                 0x92ec6d8e CMMConvTask(void*) + 54
4   libSystem.B.dylib                   0x9445b155 _pthread_start + 321
5   libSystem.B.dylib                   0x9445b012 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x13f6e250  ebx: 0x13f66af7  ecx: 0x00000000  edx: 0x0021ad80
  edi: 0x00000000  esi: 0x0021ad80  ebp: 0xbfffeb18  esp: 0xbfffeabc
   ss: 0x0000001f  efl: 0x00010246  eip: 0x00000000   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
  cr2: 0x00000000
Binary Images:
    0x1000 -    0x25ff7 +net.steventoth.HDPVRCapture ??? (2.5.0)  /Applications/HDPVRCapture.app/Contents/MacOS/HDPVRCapture
   0x85000 -    0xc7fff  com.apple.AppleScriptKit 1.5 (74) <9491bb5b0e6259b41a7a4f10201b4c23> /System/Library/Frameworks/AppleScriptKit.framework/Versions/A/AppleScriptKit
  0x10a000 -   0x11dfff +org.andymatuschak.Sparkle 1.5 Beta 6 (313) <5df2b8a3560d45006b854215644de532> /Applications/HDPVRCapture.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
  0x12b000 -   0x163fff  com.apple.OSAKit 1.1 (55)  /System/Library/Frameworks/OSAKit.framework/Versions/A/OSAKit
  0x193000 -   0x19dfff  libexslt.0.dylib ??? (???)  /usr/lib/libexslt.0.dylib
  0x1ac000 -   0x1aefff +net.wonderboots.multiclutchinputmanager ??? (1.0) <9e7f545987565ae48e64ca5fadf74e62> /Library/InputManagers/MultiClutchInputManager/MultiClutchInputManager.bundle/Contents/MacOS/MultiClutchInputManager
  0x1bd000 -   0x1bffff +com.Logitech.Control Center.Scroll Enhancer Loader 2.7.0 (2.7.0)  /Library/InputManagers/LCC Scroll Enhancer Loader/LCC Scroll Enhancer Loader.bundle/Contents/MacOS/LCC Scroll Enhancer Loader
  0x1c5000 -   0x1c5ff0 +com.google.GearsEnabler ??? (1.0) <20412f1ba06afbcd2c45b57bb0af5e68> /Library/InputManagers/GearsEnabler/GearsEnabler.bundle/Contents/MacOS/GearsEnabler
  0x1ca000 -   0x1cdfff +com.Logitech.Control Center.Scroll Enhancer 2.7.0 (2.7.0)  /Library/Application Support/Logitech.localized/Logitech Control Center.localized/LCC Scroll Enhancer.bundle/Contents/MacOS/LCC Scroll Enhancer
0x13f64000 - 0x13f6dff7  com.apple.iokit.IOUSBLib 3.2.4 (3.2.4)  /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x13fb8000 - 0x141bffef  com.apple.RawCamera.bundle 2.0.15 (471) <557c94fbd7c15219746393464a79cf87> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x14486000 - 0x1448bff3  libCGXCoreImage.A.dylib ??? (???) <3a78abc535c80f9819931b670da804a2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x147d0000 - 0x147d0ffe  com.apple.applescript.component 2.0.1 (2.0.1) /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
0x14820000 - 0x14822ffa +Adobe Unit Types a2.0.0 (2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
0x15a73000 - 0x15afafeb  com.apple.applescript 2.0.1 (2.0.1) /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
0x15bb0000 - 0x15bb2fff +com.Logitech.Control Center.Scroll Enhancer OSAX Loader 2.7.0 (2.7.0)  /Library/ScriptingAdditions/LCC Scroll Enhancer Loader.osax/Contents/MacOS/LCC Scroll Enhancer Loader
0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <45ae763de6d253ccfc0eded8d82876a6> /usr/lib/dyld
0x90003000 - 0x9030bfff  com.apple.HIToolbox 1.5.5 (???)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x90373000 - 0x90406fff  com.apple.ink.framework 101.3 (86)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9056b000 - 0x906a4ff7  libicucore.A.dylib ??? (???)  /usr/lib/libicucore.A.dylib
0x906a5000 - 0x906a7fff  com.apple.securityhi 3.0 (30817)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x906a8000 - 0x907eeff7  com.apple.ImageIO.framework 2.0.4 (2.0.4)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x907ef000 - 0x90941ff3  com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x90942000 - 0x90942ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x90943000 - 0x90943ffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x90979000 - 0x909b8fef  libTIFF.dylib ??? (???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x90a81000 - 0x91311fff  com.apple.WebCore 5530.18 (5530.18)  /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x91312000 - 0x91327ffb  com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x91506000 - 0x91531fe7  libauto.dylib ??? (???) <2e44c523b851e8e25f05d13a48070a58> /usr/lib/libauto.dylib
0x91581000 - 0x915aefeb  libvDSP.dylib ??? (???) <4daafed78a471133ec30b3ae634b6d3e> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x915af000 - 0x91653fec  com.apple.CFNetwork 438.10 (438.12)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x916d6000 - 0x916d6ffa  com.apple.CoreServices 32 (32) <373d6a888f9204641f313bc6070ae065> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x91894000 - 0x9189bffe  libbsm.dylib ??? (???)  /usr/lib/libbsm.dylib
0x9189c000 - 0x91919feb  com.apple.audio.CoreAudio 3.1.2 (3.1.2) <5a4e6329f8dbca5dcd70924525afd24a> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9191a000 - 0x9195afff  com.apple.CoreMediaIOServicesPrivate 20.0 (20.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x91971000 - 0x91a28ff3  com.apple.QTKit 7.6.2 (1327) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x91a2f000 - 0x91a32fff  com.apple.help 1.1 (36) <1a25a8fbb49a830efb31d5c0a52939cd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91a33000 - 0x91a37fff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x91a38000 - 0x91b20ff3  com.apple.CoreData 100.2 (186.1) <8fb61e1714a4b8d587ce97605ad32547> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x91c5d000 - 0x91c9ffef  com.apple.NavigationServices 3.5.2 (163) <72cdc9d21f6690837870923e7b8ca358> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x91d9b000 - 0x9243bfe3  com.apple.CoreGraphics 1.409.3 (???) <25dceb14af3455b768f56e8765ecf3ca> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9243c000 - 0x92443ff7  libCGATS.A.dylib ??? (???) <211348279493364e9920adc86484cedd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x92444000 - 0x924c1fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x924c2000 - 0x924ddffb  libPng.dylib ??? (???) <0d6b991afc831ea06f2958e5933d33dd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x924e1000 - 0x9253aff7  libGLU.dylib ??? (???)  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9253b000 - 0x925c2ff7  libsqlite3.0.dylib ??? (???) <3334ea5af7a911637413334154bb4100> /usr/lib/libsqlite3.0.dylib
0x92622000 - 0x92626fff  libGIF.dylib ??? (???) <7714ae24eb64b48fa719fb99bcbe34f3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x92672000 - 0x926ecff8  com.apple.print.framework.PrintCore 5.5.4 (245.6) <03d0585059c20cb0bde5e000438c49e1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x926ed000 - 0x926f3fff  com.apple.print.framework.Print 218.0.3 (220.2) <5b7f4ef7c2df36aff9605377775781e4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x926f4000 - 0x926f5ffc  libffi.dylib ??? (???)  /usr/lib/libffi.dylib
0x926f6000 - 0x92782ff7  com.apple.LaunchServices 290.3 (290.6)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92783000 - 0x92783ffc  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92784000 - 0x927bbfff  com.apple.SystemConfiguration 1.9.2 (1.9.2)  /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x927c4000 - 0x92995ffb  com.apple.security 5.0.5 (36371)  /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92996000 - 0x929f2ff7  com.apple.htmlrendering 68 (1.1.3) <1c5c0c417891b920dfe139385fc6c155> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x929f3000 - 0x92a7fff7  com.apple.framework.IOKit 1.5.2 (???) <97b9f9d584f48891377f0481b9104434> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x92a80000 - 0x92a80ffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x92a81000 - 0x92a8fffd  libz.1.dylib ??? (???)  /usr/lib/libz.1.dylib
0x92a91000 - 0x92aa9ff7  com.apple.CoreVideo 1.6.0 (20.0)  /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x92aaa000 - 0x92dd0fe2  com.apple.QuickTime 7.6.2 (1327) <3754e41d846b7948f96c9ec4c690b520> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x92dd1000 - 0x92e5bfe3  com.apple.DesktopServices 1.4.8 (1.4.8) <3065de6531ce839c7cb5b6dd70e03f4f> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92e81000 - 0x92f4cfff  com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x92f4d000 - 0x92ffdfff  edu.mit.Kerberos 6.0.13 (6.0.13) <804bd1b3f08fb57396781f012006367c> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x92ffe000 - 0x93185feb  com.apple.JavaScriptCore 5530 (5530.17) <687d2f3063f4d922f233623d8f219822> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x93186000 - 0x9319efff  com.apple.openscripting 1.2.8 (???) <0129d2f750f5ddcb92f4acf8a3541952> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9319f000 - 0x931e0fe7  libRIP.A.dylib ??? (???) <69bd09fcd8d8b235cee7a405290d6818> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x931e1000 - 0x93260ff5  com.apple.SearchKit 1.2.1 (1.2.1)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x93261000 - 0x9326afff  com.apple.speech.recognition.framework 3.7.24 (3.7.24)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9326b000 - 0x9334bfff  libobjc.A.dylib ??? (???) <400e943f9e8a678eea22a1d1205490ee> /usr/lib/libobjc.A.dylib
0x9334c000 - 0x93395fef  com.apple.Metadata 10.5.2 (398.25) <7eb2df3e510cd308e91a6cf6d8e9fba5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x93396000 - 0x937a6fef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9384b000 - 0x9384bffb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x9384c000 - 0x9404afef  com.apple.AppKit 6.5.7 (949.46)  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9404b000 - 0x940deff3  com.apple.ApplicationServices.ATS 3.7 (???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x94134000 - 0x94152fff  libresolv.9.dylib ??? (???) <9ed809256ce8913cddc3269c2e364654> /usr/lib/libresolv.9.dylib
0x94172000 - 0x9417ffe7  com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94180000 - 0x941daff7  com.apple.CoreText 2.0.4 (???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x942bd000 - 0x942c9ff9  com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x942ca000 - 0x9431bff7  com.apple.HIServices 1.7.0 (???) <67988718780a0a367b1bde62f5a67c4b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9431c000 - 0x94332fff  com.apple.DictionaryServices 1.0.0 (1.0.0) <7d20b8d1fb238c3e71d0fa6fda18c4f7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x94333000 - 0x9435cfff  com.apple.CoreMediaPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x9435d000 - 0x943baffb  libstdc++.6.dylib ??? (???)  /usr/lib/libstdc++.6.dylib
0x94429000 - 0x94590ff3  libSystem.B.dylib ??? (???)  /usr/lib/libSystem.B.dylib
0x94591000 - 0x94591ff8  com.apple.Cocoa 6.5 (???)  /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9460a000 - 0x94611fe9  libgcc_s.1.dylib ??? (???)  /usr/lib/libgcc_s.1.dylib
0x94612000 - 0x94650fff  libGLImage.dylib ??? (???)  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x94651000 - 0x9465cfe7  libCSync.A.dylib ??? (???) <9e3544fe087bb4dc760b7afe0850dd6c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9465d000 - 0x9470fffb  libcrypto.0.9.7.dylib ??? (???) <9d714c92872a93dd127ea8556b2c8945> /usr/lib/libcrypto.0.9.7.dylib
0x94710000 - 0x94738ff7  com.apple.shortcut 1.0.1 (1.0) <131202e7766e327d02d55c0f5fc44ad7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x94739000 - 0x94ad6fef  com.apple.QuartzCore 1.5.8 (1.5.8)  /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94daf000 - 0x94e90ff7  libxml2.2.dylib ??? (???) <2f6b294896866822330a8888b7f53b75> /usr/lib/libxml2.2.dylib
0x94e91000 - 0x94f38feb  com.apple.QD 3.11.56 (???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x94f39000 - 0x951b5fe7  com.apple.Foundation 6.5.8 (677.24)  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x951b6000 - 0x951f0fe7  com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x951f1000 - 0x951f9fff  com.apple.DiskArbitration 2.2.1 (2.2.1) <2664eeb3a4d0c95a21c089892a0ae8d0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x95217000 - 0x95221feb  com.apple.audio.SoundManager 3.9.2 (3.9.2)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x95222000 - 0x952e9ff2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x952ea000 - 0x95319fe3  com.apple.AE 402.3 (402.3)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9531a000 - 0x9532affc  com.apple.LangAnalysis 1.6.4 (1.6.4)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9532b000 - 0x957fcfbe  libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x957fd000 - 0x95826fff  libcups.2.dylib ??? (???) <1b0435164b9dc6c773d0b1f24701e554> /usr/lib/libcups.2.dylib
0x95827000 - 0x95900ff7  com.apple.WebKit 5530.18 (5530.18) <08df2c1fd856bd9b672993dacb18495a> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x95901000 - 0x95cbffea  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95d8a000 - 0x95e44fe3  com.apple.CoreServices.OSServices 227 (227) <30cebcb68b1b571df7d77474e0c31556> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x95e45000 - 0x9611fff3  com.apple.CoreServices.CarbonCore 786.11 (786.13) <9e2d85d52e5e2951aa4dd53c48ccc52f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x96120000 - 0x96120ff8  com.apple.ApplicationServices 34 (34)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x96151000 - 0x96151fff  com.apple.Carbon 136 (136)  /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x96152000 - 0x96285fef  com.apple.CoreFoundation 6.5.6 (476.18) <2d52bab73660117571bd6486dc318f8e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x96296000 - 0x962a2ffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x962f3000 - 0x96312ffa  libJPEG.dylib ??? (???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x964a3000 - 0x964a8fff  com.apple.CommonPanels 1.2.4 (85)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x964b9000 - 0x964bbff5  libRadiance.dylib ??? (???) <82d606c49f5dc77231f9d0e2be9ed6ab> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x964bc000 - 0x964e0fff  libxslt.1.dylib ??? (???) <6a58a8724941e8a0cfeb0cae28ea3f37> /usr/lib/libxslt.1.dylib
0x974bd000 - 0x974cdfff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <273d96ff861dc68be659c07ef56f599a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0xfffe8000 - 0xfffebfff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
post #866 of 1190
Goldfingiz:
The good news is that I've never seen this error and nobody else has ever report this so I suspect it's something specific to your setup. HDPVRCapture is way more stable than this so we should be able to work through the problem.
Looking at the stack trace I suspect you either have really old (or really new) firmware that is causing some kind of error. Or, you have a generic USB issue, or the device is borked.
To help rule things out:
1. Please check that your using the USB cable provide by Hauppauge to connect the HDPVR to the Mac, and don't use any USB extender or intermediate cabling. This can rule out a number of issues with whacky USB extenders that some people like to use.
2. Try different USB port on your mac. This is a reach but it's possible that one of your ports isn't operating as well as it should.
3. Go into system profiler, click on USB / Hauppauge HD PVR. What do the details show? Can you post them here? (feel free to blank out the serial number or email that to me directly). It should say Speed; Up to 480Mb/sec, Current avail 500, Current req 4.
4. Look on the label on the bottom of the HDPVR. What Revision do you have? My label says "HD PVR 49001 LF, Rev E1"
5. Which version of the windows driver did you load to ensure you were running the latest firmware?
6. If you dual boot into windows, without changing any cabling or device specifics, then run TME - does this work correctly and do you see video?
Lastly,
7. Please walk me through the exact problem. You power up your mac, connect the HDPVR, power up the HDPVR, start the HDPVRCapture software and it crashes almost immediatly? Do you do anything different to this? Have I missed a step?
Update: The serial number varies because it's expressed in decimal and hexadecimal, and has no bearing on this issue.
- Steve
post #867 of 1190
Hi Steve,
Thank you so much for taking the time to help me. I tried again today and everything seems to be working fine.
I connected the 1212 to my PC and installed the latest driver, but then stopped and decided to try the Mac again before doing anything else. I'm not sure which firmware version is on the 1212. Boot Rom Version in profiler says MBP52.008E.B00. The version of the PVR is 49001 LF Rev D2.
This time I am using the USB cable that it came with, but it's also working with the USB cable that I was using yesterday.
The only issue I encountered was no sound, but then it kicked in after I started recording and now it's on full time. I guess it was just a weird bug.
I'm going to test some more and will definitely be ordering very shortly. Thanks again for all the help, and for writing this program!
EDIT: The only other thing I'm noticing is scan lines around areas with fast motion. Is there any way to minimize this? Also, 1080p doesn't work via component on PS3, but it does on 360 for some reason. Maybe because the 360 is upscaling. This is when they are directly connected to my TV. To play through the Hauppauge I need to be in 720p or 1080i, right? No way to keep the 360 on 1080p and record in 720p/1080i? I guess I'll have to play at 720p when I want to record.
post #868 of 1190
Originally Posted by Goldfingiz View Post
Hi Steve,
You're welcome. A strange issue for sure, at least it's gone.
The act of connecting your HDPVR and installing the latest driver would force a firmware update if it was required.
ok.
Yeah, I guess so. You can pick the audio input in the UI. If you pick the wrong thing then you'd probably get not audio.
Great, thanks.
I suspect you're capturing interlaced content, a decent player should be able to deinterlace for you or capture progressive instead.
Correct, the product does not support 1080p, only 1080i or lower.
Yes.
1080i or 720p for recording should be fine.
- Steve
post #869 of 1190
ok.
Great, thanks.
Yes.
- Steve
Thank you so much Steve, going to order right now!
post #870 of 1190
Goldfingiz: You're welcome.
Happy customers = happy Steven.
  Back to Forum: HTPC - Mac Chat
