Originally Posted by
roman707
I have auditioned the B&W 800 series, and I must say the 803D's sound great. I know these are pricey, can you guys make any other recommendations that would be similar.
Maybe I'm just a pleb, but I have to think that at these prices diminishing returns would have long set in.
I'm not sure what would sound like them--do you mean something just as or nearly as high in quality but less expensive, or something that is voiced like them? To me, most B&W speakers have a laid-back midrange and emphasized mid-bass and low-treble (sort of a "smile curve"), and are on the warm side overall. My opinion, based on limited experience (auditioning years ago in a store), is that B&W speakers that fall within your price range are a bit unclear in the midrange in comparison to those of other well-known brands. They might have improved the 600 series since then, but I wouldn't know.
Kal Rubinson
You will have acoustical problems with an 18' cube of a room since, when all the dimensions are identical, all the room modes will sum. I suggest that you seriously consider lots of bass traps or electronic EQ.
Wouldn't having more than one subwoofer also help mitigate the room mode issues of such an extreme case?
roman707
OK, so I will be purchasing either the Pioneer SC-05 or Denon 3808ci reciever to go with my new plasma.
Between the two, the Denon has the more sophisticated room correction system (which is important for your room in particular), and I've always favored the sound of Denon receivers--they have pretty solid amp sections. If you can get it for around $1000, then that would leave around $3000 for speakers.
roman707
I need to find a good speaker setup that the reciever can handle. I will be using this system for 90% movies, not much music at all. Also, I was hoping to find something that is wall mountable, because I have a newborn coming. Any suggestions??? I heard the SVC system is great for movies, but I can spend more if there is something better.
Do you mean SVS? Their systems should be suitable for both movies and music. I only have experience with their less expensive series, having installed one such system for somebody else and listened to it quite a bit. The
5.0 Multi-channel SCS-01(M) speaker system with SBS-01 surrounds should do fine (and is easily wall-mountable with keyhole slots)--together with a
PB13-Ultra to rock that big space, the cost would be about $2200, depending on options (e.g. +$130 for larger surrounds, +$100 for gloss black PB13-Ultra, -$200 for the
PC13-Ultra instead).
The SVS MTS series is the next step up and may squeeze into your budget (bulging it a bit), but having never heard these speakers myself, I don't know whether they bring many improvements for HT use as opposed to critical music listening (others with personal experience can comment on that).
Another recommendation that may seem a bit unusual to some would be three vertically-oriented
Ascend Acoustics CBM-170 SE bookshelf speakers mounted (using the
B-Tech BT77) at the same height, just above your TV if it is mounted at eye-level, or below it if it is mounted higher. This should improve imaging over other solutions--personally, I hate when the front speakers are at different heights, but maybe that's just me. Other advantages of this system over most others is relatively high efficiency and power handling--some speakers in this price and size range (for wall-mounting) are just as efficient or can handle just as much power, but not usually both at the same time. This translates to improved dynamics, which is good for HT as well as music. You can use two more of these speakers for surrounds or the much smaller
HTM-200 SE if that would look better in your room. Along with a PB13-Ultra subwoofer, this system will cost about $2400.
Since you have room left in your updated budget for the
Sierra-1, obviously that's another option to consider. You'd give up some efficiency for even cleaner sound, although I'm not sure how much difference that would make for movies as opposed to music (and the CBM-170 SE is darn good at music, too). The speakers are voiced similarly--neutral in tone with flat frequency responses. The Sierra-1 does seem to have a more controlled vertical dispersion by design, which may help with your type of floor. If you're interested at all, you might want to
contact Ascend Acoustics and ask them about these issues.
