Hi, I'm installing a Slingbox in a remote location and was wondering what's the best way to bring that video into the whole house. I currently have a PC with A/V out, and I'm using basic cable (no cable box, no internet through this service) and all the rooms are currently connected with the basic cable service. I've been reading about the use of a modulator to inject an extra channel into my existing coax cable. How should this be done? I'm wondering if I could just use the Channel Plus 55x5 series modulator and run the coax output of this unit to a combiner (two way splitter used to combine the signal) that would combine my Slingbox video feed (Let's say Channel 103, an empty channel in my cable service)? At what junction point do I put in this combiner? Do I have to run a new coax run from the room where the PC/Modulator is to the main splitter (is that called a drop?). Or can I just run the coax into the existing coax with a combiner in the same room and call it a day? (I'm thinking it couldn't be this easy.) Also if I inject this signal with just a combiner, would my neighbors see the same channel? How do I block it so the new channel only shows up in my house? I'm trying to do this with very little money.
Sorry for all the newbie questions. Any help is appreciated.
