Originally Posted by
philoso4
With the box turned OFF, you click the "SETTINGS" button on the remote and a menu appears. You scroll and change various settings, among them the caption setting. It is the only way to turn on or off.
philoso4
If you perform the "SETTINGS" routine I mentioned in the previous post, what setting do you see for your audio? I have not found an audio setting that allows output to the digi coax.
I have no 'settings" button on the remote but with the box off, the 'guide' button shows a menu, which I have never seen before. There is no option in it to change the audio output. Do you have a Comcast remote or an old Adelphia remote, which did have a 'settings' button? I do see an option to change the CC, which would be more convenient to me than going into the setup in the menu. I can change the CC in the menu also while the box is on.
My STB is the SA 8300HDC with the new SA25 guide, silver Comcast remote.
