^^Thanks. For clarification, let me say that, looking at the board, I assumed the ribbon cables were like the cables that are like a pc dvd drive, the flat cable with the connector that you plug or unplug. But as I discovered, the ribbon is just that, a ribbon, the flat plastic 'head' is attached to the board itself and not the end of the ribbon. That's what had me scratching my head. I honestly thought I'd torn the thing when it the copper ribbon came sliding out (I wasn't pulling on it). Note to any others who may wish to swap drives-it;s best not to unscrew the board from the drive, leave it screwed to the drive and remove the ribbons first. It was harder for me-a first timer at least, to figure out when I unscrewed the board first, expecting to disconnect the cables with ease afterward.
And the final results. Installed the VXY1961, screwed everything back into place and plogged in...the ez48 works again. Thus far, I played a RAM disc, and it's recording right now, tested chase play, commercial skip while chase play, stop playback while recording, and everything's working..,
Many thanks to Digado, Wilmorr and all other contributors to this servicing thread. Great advice and direction found here on the mighty AVS Forum.
so the latest one was repaired by the formerly mentioned MICKINCT. If your machine is making the noise in
How does that differ from the EH-55 and what country are you from?
Glad it worked out OK for you though.
