AVS › AVS Forum › Display Devices › Rear Projection Units › HDMI input to an Pioneer Pro 520 hd
post #1 of 2
Hi to all.
I have a satellite receiver SV 8000HD the output from the satellite receiver to the TV is a HDMI connection but my Pioneer Pro 520HD do not have a HDMI input only component and RGB.
I like to know if anybody know about and switch or adapter to use with my TV set and made an HD resolution.
Thanks to all.
post #2 of 2
Assuming your unit does have a DVI output get a dvi to HDMI cable or use component cables since the unit will output HD programs over either.
  Back to Forum: Rear Projection Units
