I opened the attachment and I do not have a clue on how to proceed with getting the codes for Audyssey functions
. I just see a bunch of numbers and letters. Is there a certain procedure to do this? Thanks in advance for any advice .Bill |
Here's how I got them loaded:
- First, I extracted all of the hex code from the spreadsheet for the commands I wanted and placed them into a plain text file - see attached file OnkyoHex.txt... (You're Welcome!
) - I created an email "incident" using Harmony's online support pages. The body of the email was:
Please add the commands in the attached file to my account:
Account Name: xxxxxxx
Device: Onkyo TX-SR876
Thank you for your assistance.
- I attached to the email a text file with the subset of commands I wanted to add... I did not attempt to inundate them with ALL the commands in one request... I split it up over three separate requests in about a months time. An example of the attachment is also attached here.
- Every time I made a request, the commands were succesfully loaded by 5pm the next business day. Kudos to Harmony CS for the excellent work.
BTW... at this point I have all of the commands in the "full" document loaded and tested with my H1/876. Everything appears to work except AudioAdjust... I have no idea what its supposed to do... [Update... AudioAdjust was for 806... removed from file]. I also did not submit (or extract) the 886 or 906 specific commands like the discrete trigger commands (886) or streaming audio commands (906). If I get the time this weekend I may do that and repost an updated "full" hexcode file for you.
[EDIT: Updated "OnkyoHex.txt" to include 886/906 specific commands.]
[EDIT: Added original Onkyo spreadsheet document]
[EDIT: Updated "OnkyoHex.txt" to correct Audyssey ON/OFF/WRAP hex codes.]
[EDIT: Updated Onkyo spreadsheet to 08/09 document with xxx7 models]
[EDIT: Updated Onkyo spreadsheet to 07/10 document with xxx8 models]
[EDIT: Updated "OnkyoHex.txt" to include all Main Zone codes for 876/886/906/3007/5007/5507/3008/5008/5508 models]
SampleHarmonySubmittal.txt 7.2685546875k . file
Onkyo_IR_AVR_121_(thru_2010_models).xls.zip 212.01953125k . file
OnkyoHex(v2.0).txt 99.6533203125k . file
. Now another brilliant question, do you just copy and paste the whole line of code for each command you want added to the request form for Harmony?
. Thanks to gurkey for posting the updated FW's and keeping the thread up to date. Also thanks to rickardl for the detailed instructions in the 876 thread on the update of the FW. I needed those instructions as I could not get the instructions to open as part of the 1.04 download
Any one getting low chirps volume during the Audyssey procedure??? Can't hardly hear the little birds calling! So I'm getting error sings..
