Good to know! Thanks.
post #1081 of 3210
6/3/09 at 5:44pm
On a semi-positive note, TWC in this area is slowly rolling out a new samsung dvr but it's hard to get at the moment... not sure if this one might address this problem but I suspect it's running the same TWC Mystro software.
)... you are comparing the 886 to an 805. Were you using the the 805 as a preamp with external amps or with internal amps? If external amps, are they the same as you are using with the 886? If they were not the same amps as you are using now, then that is another variable in the equation you are trying to solve.
