Originally Posted by DKAudio
Thanks for the reply. Are you referring to the setting the allows audio to pass through the HDMI and into the TV? I do have that on so I can watch TV without needing my XPA-5 on all the time and just use the TV speakers. If that is enabled what does that mean as far as video processing and the Reon chip? The picture doesn't look upscaled to me but all my picture settings are at the factory default of 0, maybe I need to adjust those?
Thanks for the list of Audyssey settings, that helped a lot!
A real simple way to figure out if the 886 is upconverting the signal is to hit the info button on your display to see what signal it is receiving. Use a source that you can change the resolution on. For example, set your BR player to output 720p. Then check the info on the tv to see what signal it is receiving. If the tv is receiving a 1080p signal and the BR player is outputting 720p then obviously the 886 is upconverting the 720p incoming signal and outputting it as 1080p.
Does that make sense???
