Originally Posted by tzjpam
I have the same problem and when I contacted the Samsung Tech this is the reply I got:
"The problem that you see is normal operation on phosphor based display panels due to how each individual phosphor cell is charged/discharged individually.
Plasma displays operate on X/Y/Z coordinates, this phenomenon you see is called "cross over charge", where certain columns/rows are crossed with the area that is being charged differently than the current area (X/Y/Z addressing).
this phenomenon will be seen on any phosphor based plasma display panel.
Samsung to state that this is "normal operation", and "seen on any phosphor based plasma display panel" is totally wrong. I went through 5 58A650's, all had line bleed, and I got the same answer from Samsung. I purchased a Panasonic to replace it and it has @ 1/10th the line bleed. I also have a Pioneer 151hd, and it has absolutely no line bleed.
