Hi All,
My TV is LG LCD TV 47" 1080P ( I think the model number is 47LC7DF). I have it for couple of months. Somehow its has been turn off by itself a week ago. When its off, I have no way to turn it on either using remote control or the power button. I remove the power cord for more than 1 minutes, then I plugged it back in the TV and turn it on. Its working for few days without giving me any problem.
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick above, remove power cord and plug it back after 1 minute. Then its turn on again, but I'm in the rush to work. When I leave, the TV was on. But just now I got the message from my wife, she told that they are unable to turn the TV on. I told her I was turn on the TV before I went to work. She told that after I left the home, the TV seems liked in "off", not turn on.
DO you guys having the problem ? Have any idea what solution I can have this fix without asking for repair service? Appreciate your help, Thank you.
Then it turns on and off repeatly again. Then I turned it off using the remote control. Its off for few minutes, I turned it back on, its became normal again but also only last for 10 minutes or more. I tried it few times, the TV still turned on and off repeatly after 10 minutes.
Whats seem to be the problem?
