I am 77 years old. Have a 1991 RCA TV. Bought a Digital Stream converter box from Radio Shack and hooked it up. Set for channel 4 (3 is in use in our area).The converter box has a universal remote. Checked all posibilites for the remote and found several which would turn off the TV but none would turn it back on. When I turned it back on with the old remote, the screen showed welcome "set up wizard" with select and next options. Select was direction 4 arrows and an OK in center for choice of language (English was there). None of the arrows work neith does the select nor next. Setup wizard goes no further. I can't even shut off the converter box with the remote. I have to pull the plug. Is the set to old or what can be done?
AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Problems with Digital Stream
