AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › TH-50PX80U-vs-PN50A400 First Plasma,Help
post #1 of 5
1 :Well the title says it all. Both TVs are the same price on black friday The Panny would require an overnight stay @ BB and the Sammy is at Sears not a door buster so no sleeping over.
2 : Also can anyone confirm that the Panny at BB is the TH-50PX80U. The web sight i use for black friday stuff does not have the model # for the Panny just says 720P 50 inch panasonic.
3: One more thing does anyone know the difference between the Sammy PN50A400 and the PN50A450. any knowledge would be great.
post #2 of 5
post #3 of 5
I believe they will have the Panasonic 50" TH-50PE8U Class 720p Plasma HDTV advertised.
Chris
post #4 of 5
Well, you can find the Panny for $100 more almost everywhere now. Is it worth the hassle of black friday just to save that much?
post #5 of 5
I got the Panny PX80 for my daughter at BB a month ago for $997.99 With Free Delivery. If I was you I would see what the Forum Sponsors (MonutAVision & Etc) can do for you & remember "Delivery" is important on these big sets because there not going to fit in any Car or most SUV's & if you get it home & the glass is broken your going to be out of luck.
I think my daughter might have lucked out with the delivery guys because they unpacked the tv for her, attatched the base to it & plugged it in to make sure it was working correctly & took the box & all the packing material away for her.
I went with the Panny over the Sammy because it has Better Blacks, Better Sound Quality & to me most of all Better Build Quality & Service.
Sorry I don't know the difference between the Sammy 400 & the 450 but I'm guessing it's only some small things like maybe the 400 doesn't have a PC Input?
