AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › Best flashplugin for linux?
post #1 of 6
I'm using Hard Heron, and I don't think youtube and google video play very well. I was trying to watch some google videos last night and they were too choppy to watch.
I read on this website that you can install flash 10 which is better. So I followed the instructions and went to this page and downloaded the .deb, use the package manager gui to install it, but when I go to firefox and type about : plugins, it says
File name: libflashplayer.so
Shockwave Flash 9.0 r124
So did it really install flash ten? Is flash ten what I want for the best playback? Does google video use flash?
post #2 of 6
All you should need for Ubuntu 8.04/8.10 is the Ubuntu .deb installer at Adobe-
http://get.adobe.com/flashplayer/otherversions/
Also, Flash should auto-install on Firefox in 8.04/8.10 when you hit a site that needs Flash, except Youtube- try pogo.com to get the auto-install popup.
post #3 of 6
Well I have a flash plugin, becaues youtube works, I'm just not sure if it's the best one I colud have. That website I posted said that you could go to the backports and install version 10 and that it was better than 9. I did it, but when I check in firefox I think it tells me that I still have version 9.
post #4 of 6
If I remember right, if you did the synaptic install of Flash, it really put the flash library in /etc/alternatives or something. Check your actual /usr/lib/mozilla/plugins to see if there is an old link in there pointing to /etc/alternatives. Worst case, go uninstall flash through synaptic and do the deb install manually if needed.
-Trouble
post #5 of 6
Someone else can chime in on how to remove Flash 9 before installing Flash 10.
Another point is to ensure you have the proprietary ATI or Nvidia driver installed/enabled, and if using Nvidia, copy/paste the following to the Devices (nvidia) group in your xorg.conf file:
Option UseEvents "True"
This option reduces CPU utilization for video.
post #6 of 6
See this is confusing which is why I made the thread. I never uninstalled Flash 9, because I didn't know I had to. I never uninstall anything else before installing anything, apt does it for me, like I didn' have to uninstall firefox 2 before firefox 3.
I tried to install flash ten like that website said by downloading it, and I also tried adding the hardy-backports repository and running apt-get install flashplugin-nonfree, but still firefox said it was shockwave flash 9. So I went to that adobe site, and now firefox about: plugins says flash 10. But my friend did the same thing and HIS firefox still says flash 9 even after the adobe site.
The computer in question doesn't have an nvidia chipset as far as I know, it's an Acer Aspire One netbook, and I don't know what kind of video card it has.
This is all very complicated.
  Back to Forum: HTPC - Linux Chat
