AVS › AVS Forum › Audio › Receivers, Amps, and Processors › SET-UP HELP with bdp-s550 and denon 2807
post #1 of 2
set-up help
i have a denon 2807 and i am thinking of upgrading my DVD player to a sony bdp-s550. how should i set this up so i get the best sound and video quality i can achieve.. thanks in advance for the help. what are the settings that i would need to set on the blu-ray to achieve these results.. and also how would i set it up???
thanks
post #2 of 2
I ahve the same setup and am still attempting to make it work properly. Surround sound is fine, very little output from my sub though. Does your auto setup turn your sub down 12 DB when you run it?
