I need help adding better sound to my living room setup. Sources are a HD TiVo, a PS3 for blu-ray and MP4s, and music from an iPod or streamed via AirTunes. The space is an asymmetrical 600 sq ft modern loft with 11 ft ceilings.
I have a HK DPR 1001 with mid-level Polk 5.1 speakers sitting in my garage because my wife didn't like the speakers everywhere and the complexity of the A/V receiver. I also have some Athena AS-B1 bookshelf speakers in my garage.
Currently I use my Panasonic plasma's built-in speakers for TV/movies and a Klipsch iGroove HG for iPod/AirTunes.
I have a small budget and would like to stay under $500 but may be willing to spend a little more.
I have a mounted 50" flat screen over two of the entertainment shelves pictured below. I need to have the speakers sit on top of the shelves. Soundbars won't work as they are too long and the shelves are stacked with books.
I am looking for the best 2 channel sound I can afford and I don't need an upgrade path to 5.1 or better. A 2.1 speaker setup could work but the sub would have to be flat enough to fit under the shelves. My options seem to be:
1. A simple, slim integrated amplifier or receiver and use my Athenas. I'd like something under 3" tall that doesn't generate too much heat. I found the Rotel RA-04 online but I don't think they offer this in the US. This way I could also upgrade my speakers later on.
2. A high end ipod powered speaker/dock setup
3. Powered studio monitors
4. Also, if I add a sub it has to be slim enough to fit under the shelves.
Any suggestions? Thanks!
