Alright I have been fixing up a 1985 Zenith Projection Monitor Pv800p.
It's probably the first projector they made.
At this point the projector is working. I could probably still use a new blue and red tube. But it is working just fine for now.
My question to you guys is.....
How do I go about setting this bad boy up.
I have no service manual. But have an idea of how this projector is adjusted.
I know how to do. Horiz and Vert position
Focus, intesity, and there is one more control....it's sorta like the horizontal position. But it stretches it....from side to side....It's hard to explain.
Also I figured out a way to adjust horiz size.
Theres DEFINATLEY more. But these are small vari resistors often only labelled with a R G or B for determining which tube it is affecting(actually all of the adjustments are labelled like this, but I just won't touch the smaller ones).
But how do I go about adjusting these. As you all know adjusting one single control can fix one problem but then makes 10 other problems apparent.
I know it involves covering one crt as you do the adjustements but I just don't know. I don't even know how far from the screen I should even have the projector for best results.
My hopes are that one of you who actually may have seen one of these working can tell me some general stuff. Like the screen distance!
Any help is greatley appreciated.
Rudy
Rudy
