I like your taste. The speaker raceways actually are so small that they look really good. I am not a fan of cornering entertainment centers in the room, especially next to a window, but that's just me.
Is that a fireplace to the left of the tv?? hmmmmm.
Probably not the best setup for overall sound and theater effect (speakers so close to the walls and TV), however, I like it. Everything's extremely neat and tidy, and it looks like you have made great use of very limited space. In certain rooms, potential sound quality just has to take a back seat to aesthetics and feng shui.
thanks for the comments. Yes, the TV is in the corner, next to a fireplace. There really is just so much you can do with the space. However, I would like to upgrade from my 40" Bravia to a 46" Bravia. If i get rid of the towers, you think it'll fit
I was implying that maybe you could wall mount it above the fireplace?
I think that would be awfully high for the TV, considering the apparent short distance to the seating. The TV would be at least 30-36" higher than it is now.
