Originally Posted by HTPCBootProblems
Hey guys, can anyone help with this problem i Have?
I have been attempting to make this HTPC build work, here are the following components:
Power Supply: Antec 380 Watt Power supply (came with the Antec Sonata case)
Processor: Intel Q8200 Quad Core
Motherboard: GIGABYTE GA-E7AUM-DS2H
The problem I am having is that the build would not post, it would get power but no beep codes whatsoever. CPU and case fans are spinning, but no monitor signal. I tried clearing the CMOS but still no go. I figured without the memory or hard drive it would complain about it but nothing.
I have also tried a new powersupply, an Antec 500w still no post. Would I need a higher wattage power supply than 500?
I have also RMAed the motherboard so this is a 2nd new motherboard from newegg. My only other conclusion is that the CPU is bad however it is also new. I guess my last resort is to RMA the CPU but I just want to check the forums before RMAing it.
I guess my questions are:
Is there anything else I should check before RMAing the CPU?
When this board boots up without a video card installed which video port does it access? (vga, hdmi, dvi)
Do I need a higher power supply?
Thanks in advance.
Thanks in advance.
Have you considered the RAM? Try with one of the two sticks then with the other.
