Originally Posted by pizzaman79
Thanks. I swapped the Scythe shuriken on my cpu for a Scythe big shuriken and the Antec NSK1380 case is now replaced by a Lian Li PC-V351B. This alone brought the temperature down to around 60', without an active fan.
Gigabyte had a great tech support and confirmed that these are quite normal temperatures, so i'm gonna accept them for now. I'll probably replace the internals for ivy bridge as soon as gigabyte brings out a nice htpc/server uatx mobo. Already bought my DDR3 memory, as prices are about to rise :-)
My chipset runs at about 39 degC using one of these:
http://www.newegg.com/Product/Produc...82E16835200034
The fan pulls air down and then out over the components around the CPU including the chipset heatsink. If your CPU fan doesn't direct air over your chipset heatsink, you will have a hot chipset. I started with a passive CPU cooler, but found out quickly that it didn't cut it for this chipset. There was a lot of hot chipset discussions in this thread when this board was released. Take a look.
Tim
